rear brakes
Old Feb 28, 2008 | 11:05 AM
Death Cattle's Avatar
rear brakes
does anyone ever use them in any situation?
Old Feb 28, 2008 | 11:08 AM
Blue Ridge Boy's Avatar
Are you serious? No offense
Whenever you come to a stop you should always use both brakes.
Mid-corner if you are going too fast...a little rear brake can help you out.
There are many cases where you should use your rear brake.
You just need to be careful when using them.
Old Feb 28, 2008 | 11:30 AM
im just wondering, i use them a little, but i havent found a whole lot of situations where i need them.
Old Feb 28, 2008 | 11:37 AM
ride harder and faster and you'll find yourself using them more often
Old Feb 28, 2008 | 11:56 AM
StoneJrW's Avatar
StoneJrW is on a distinguished road
I use both brakes all the time when stopping. I use either or when just slowing down a bit like in traffic.
Old Feb 28, 2008 | 11:59 AM
Have you ever taken the MSF course Death?
Old Feb 28, 2008 | 12:09 PM
While front is 90% of your braking force, the rear is quite useful in many situations. The main thing is to not lock up the rear while in any kind of turn, that'd be bad.
Old Feb 28, 2008 | 12:39 PM
trinc's Avatar
when traction is questionable aka riding on sand, gravel, oil etc. etc. use the rear brake... other than that i mainly use the front.
if you need a lot of brake most likely you have a fist full of front brake ... which will lighten the rear end & make locking it up more likely.
imo - people have no idea how hard they can brake ( front ). many have never even heard a tire howl ( the point just before losing traction ).
many many years ago i took the rider course and had this same discussion.
( background : i was in the class for reasons other than getting my endorsement )
it ended with a demonstration by which the instructor used only the front brake then both brakes. obviously using both brake he had a shorter distance. i got on the bike and stopped shorter with just the front brake & said i guess it's just how hard your willing to pull the lever.
but...
advanced riding skills: there are times when using the rear brake has an advantage over using the front brake and sometimes even in place of the throttle. i don't think thats is what is being asked so i won't complicate any answers.
tim
Old Feb 28, 2008 | 12:42 PM
Josh's Avatar
Minimal Post
Josh is an unknown quantity at this point
Yes. There's no question that 3 discs being squeezed will stop you faster than two, even if the rear is smaller. I like to make use of all the stopping power.
Old Feb 28, 2008 | 12:54 PM
trinc's Avatar
that statement is very misleading... imo MAXIMUM braking would require you to RELEASE the rear brake.
tim
Old Feb 28, 2008 | 01:28 PM
whats the MSF course of death? thanks for all the opinions guys. im pretty new to riding on the road, but ive been riding dirt bikes my entire life, so im getting used to what brakes work best when. mainly the best times to instinctualy use the rear brakes.
Old Feb 28, 2008 | 01:32 PM
The MSF (Motorcycle Safety Foundation) course is a weekend long course you can take that will help with your riding skills. You'll learn proper techniques and become a better rider, and get a discount on your insurance. I think a few members here are certified instructors for the course.
Old Feb 28, 2008 | 01:41 PM
trinc's Avatar
basic techniques for new riders.
tim
Old Feb 28, 2008 | 01:51 PM
motojoe's Avatar
Sexual Daredevil
I use both. Different situations call for different techniques. Practice using both brakes, together and separately. Get comfortable using them. Over time you too will discover how and when to use them properly. Feel it for yourself. Some riders use two fingers on the front lever, while others use one. Some even use four. Use what ever keeps you in control. Adjust your levers to fit your fingers and foot. Hard braking in a straight line upright, softer braking when leaned over.
Old Feb 28, 2008 | 02:51 PM
autoteach's Avatar
rear brake:
tightens lines in corner, allows you to "suck down"
used to evaluate road surface. If you notice a change in surface, you can add rear brake until lockup to determine the amount of grip
if you run onto gravel, bias your braking towards the rear to avoid washout
etc etc
There are many uses,get a book on riding techniques, even if it is aimed at track/sport reading, they will address the uses of the rear brake
viperkillertt
Aug 17, 2010 10:42 AM
dn4sand
Dec 18, 2009 12:32 PM
LC4CARL
Oct 14, 2009 06:14 PM
dondiggdy
Jul 23, 2009 11:15 AM
