Radiator rust
Radiator rust
I'm swapping from broken radiator to one I purchased used from someone else. Looks like a rust film thruout. Is this ok? Or should I not use it? Possible to clean out? Image attached to view and compare. If any idea, let me know.
I would clean it. I'm pretty sure most radiator flushing chemicals are meant to clean out rust so I would drop it in a 5 gallon bucket mixed with hot water and rad flush and let it sit for a while maybe a day or 2(but keep an eye on it) and see if it does anything then flush it out with your garden hose...
It doesnt look bad enough to foul things up or prevent good heat exchange.
Run it and change the coolant after a thousand miles.
Thanks for posting. It makes me realize I need to flush the cooling systems on my vehicles .
Scoutpilot
Sep 9, 2008 10:00 PM
RedHotFireStorm
Dec 11, 2006 05:44 PM
