Plastic shroud
Old Dec 17, 2013 | 11:32 AM
Willyjaman's Avatar
Willyjaman is on a distinguished road
Plastic shroud
Just curious if the plastic shroud under the carbs is needed or is it ok to remove it. Will the fuel get too warm if the shroud is removed?
Old Dec 17, 2013 | 12:02 PM
insulinboy's Avatar
Its a heat shield. It is there not only to protect the carbs, but cables, wires, and to keep your tank from heating up and causing all your fuel to evaporate out of the tank when the pressure builds
Old Dec 17, 2013 | 12:27 PM
I always thought that thing also helped facilitate a calm air pocket for the snorkel to pull from.
Old Dec 17, 2013 | 12:41 PM
I'm pretty sure that's what the consensus was.
Edit: When I assembled my bike, I forgot to put that plastic piece in. Once the engine was installed into the frame, you can't slide that piece in, so I left it out. I have a couple thousand miles on my bike now without it and it runs pretty dang good.
Old Dec 17, 2013 | 01:16 PM
If you paint it yellow, it's 5mph top-end. I have the salt-flat results to prove it.
Old Dec 17, 2013 | 04:38 PM
Upland111's Avatar
Interesting.....
When I bought my Hawk in 09', I never knew there was supposed to be a shroud under the carbs, and I have had my carbs off several times.
So I went to Ron Ayers to look up the part number on the fiche....And I don't see it?
Could someone point out the part number for this piece?
Thanks much
Old Dec 17, 2013 | 04:45 PM
Look on the parts page for Frame.. parts 1, 2 &3
GUARD, HEAT
19125-MBB-010
002 COVER, R. HEAT GUARD
19126-MBB-000
003 COVER, L. HEAT GUARD
19127-MBB-000
Old Dec 17, 2013 | 06:03 PM
I removed mine when I put the Dynojet kit in and have done approx 13,000ks since with no apparent problems.
Our climate is pretty temperate here, maybe that helps too!!
Old Dec 17, 2013 | 09:36 PM
Upland111's Avatar
Thanks for the pic E. Appreciate your response.
So I had to go out and pull the blanket off the old girl tonight and check it out. Hmm, I see the left and right plastic scoops on either side of the front carb, and below I see the thermostat and front MCCT on the left side, and the overflow coolant reservoir resting below the carbs.
Just when I thought I knew her pretty damn well. So I Google "carburetor heat shield Superhawk" and go to images and here is what I get.
97-05 Honda VTR1000 VTR 1000 Superhawk Engine Inner Cover Shield Heat Guard | eBay
I take it this is the part? Am I completely blind, or does this really sit below the carbs/coolant reservoir? I can't believe I have to ask again so bare with me on this one. Shhhheesh
EDIT: OK. This part sits behind the steering stem, not under the carburetors. The OP statement threw me. My bad.
"Just curious if the plastic shroud under the carbs is needed or is it ok to remove it."
Old Dec 18, 2013 | 06:42 AM
Yes that is the part being discussed.. and yes, it is not BELOW the carbs.. but above and forward somewhat.
dudeitscristhian
Nov 3, 2014 10:12 AM
BIG DAVE 03
Jul 7, 2012 11:55 AM
ff
Jan 1, 2009 08:18 AM
OldHawkNewB
Nov 26, 2006 06:58 PM
98vtr1000
Oct 18, 2006 01:40 AM
