Plastic Rivets
Old Nov 27, 2007 | 01:32 PM
comedo's Avatar
Plastic Rivets
The fairing is attached to the left rad and the area near the fan by plastic rivets. I've been using expensive genuine Honda plastic rivets and I've been able to transform them into genuine junk. The rivets should be reusable but when I put them back in either they don't hold or I strip the phillips heads or threads on them. Are there any good alternatives to the OEM rivets other than cable ties?
Old Nov 27, 2007 | 01:38 PM
bkelsey's Avatar
bkelsey
I'll be watching this thread. I hate those little POS.
Old Nov 27, 2007 | 01:52 PM
trinc's Avatar
they are also used in the auto industry. i buy them at a regional chain store ( maybe national ? ) schucks auto supply. very common part.
tim
autoteach's Avatar
You can purchase replacements at a portion of the cost from Fastenal. You need to look in their automotive section. I will post when I find it.
Bill
Old Nov 27, 2007 | 02:07 PM
autoteach's Avatar
http://www.fastenal.com/web/products...99604789&Nty=0
Have fun finding it, but I know that it is there
Old Nov 27, 2007 | 02:09 PM
autoteach's Avatar
http://www.fastenal.com/web/products...99819216&Nty=0
One step closer
autoteach's Avatar
http://www.fastenal.com/web/products...ex?sku=0162662
Well, now we just have to check the size, and that is up to you.
Bill
Old Nov 27, 2007 | 02:11 PM
autoteach's Avatar
But wait, you say, these are over 9 bucks!
that is for 25, and if you know the retailer like I do, you will pay between 7-8 biggee's. That isn't bad when the Auto manufacturers are charging $25 for 5 of them!!!!!!
Old Nov 27, 2007 | 02:29 PM
comedo's Avatar
Thanks, Bill. Really appreciate it.
Old Nov 27, 2007 | 02:47 PM
Yeah, thanks Bill! My local Honda shop sells these for $3.25 each. I bought some from Ronnies but they are too big.
Old Nov 28, 2007 | 04:51 AM
autoteach's Avatar
Just make sure that you get the right size!! The reason that I found out about these is I did a fan relay on a jeep grand cherokee, and we needed to take the bumper off, thats right, to get to the relay wich was below the headlight. to put it back together we need to replace the rivets, which I got a "deal" on from the chrysler dealer for $17 for five of them. It would have cost me $8 for 25 from fastenal, but I didn't know that they had them until afterwards. It sucked.
Old Nov 28, 2007 | 06:57 AM
superbling's Avatar
Most autoparts and/or hardware stores have these types of fasteners at a price in between your friendly honda stealer and fastenal.com
Superbling came without them and I never got around to putting any back in; never had an issue and fairing removal was even quicker. I had two sets of bodywork and switched out many a time; no rubbing, paint missing, etc,. YMMV
Old Nov 28, 2007 | 07:41 AM
Mine went missing a long time ago and I never bothered... No damage as far as I can see...
Note: and I even have some laying around... Mazda uses em all over the place in plastic parts in the interior...
Old Nov 28, 2007 | 07:44 AM
SlowHAWK's Avatar
I bought a rubber grommet with a brass threaded fitting in it, and used a small stainless hex head bolt (like the ones used to hold the fairings) to replace those stupid items. You can find this stuff at Home Depot... for like 3 bucks, you'll have something that shouldn't strip (unless you muscle it too tight) and you'll actually be able to remove it.
*** You will need to drill the hole a bit larger to fit the rubber grommet.... but 30 seconds to widen the hole, and toss those plastic parts was well worth it.
J.
Old Nov 28, 2007 | 10:04 AM
killer5280's Avatar
J.
I like this solution. I am still using my original plastic fasteners, believe it or not, but I have cussed those things so many times.... They're a bitch to remove, which isn't made easier by the fact that you can't see them unless you crawl under the bike with a light and slip a knife edge under them.
Old Nov 28, 2007 | 10:27 AM
Thumper's Avatar
+1 I just use a tiny eye glass type flat blade screw driver to lift the screw peice out and then remove the both peices.
Old Nov 28, 2007 | 11:27 AM
autoteach's Avatar
if you have new ones that are not worn, or stripped, light pressure on the screws will allow you to remove them by unscrewing them. Past that, you will need something to pry them out.
AC COBRA
Dec 10, 2006 09:41 AM
OldHawkNewB
Nov 26, 2006 06:58 PM
98vtr1000
Oct 18, 2006 01:40 AM
floridasroadkill
Sep 29, 2006 08:32 AM
bluesman
Aug 30, 2006 09:13 AM
