Passenger Peg Bracket Interchange
Old Apr 27, 2014 | 11:58 AM
Storm_Chaser's Avatar
BlueBirdin'
Storm_Chaser is on a distinguished road
Mounted Micron High Mounts and in the process they delete the passenger pegs. This is unacceptable to the lady so does anyone know of any passenger peg brackets that have the correct bolt hole spacing? From a quick run down on ebay it looks like some 99' CBR900RR or 03/04' CBR600RR pegs might work. They just need to come out and down a bit to clear, no sweep forward or back is necessary. Short of machining some new ones, thoughts?
- SC
Old Apr 27, 2014 | 12:28 PM
Short version-Many (but not all) aftermarket systems came with longer bolts and spacers to move the pegs out past the mufflers. You would either have to find them used or go to a bolt supply house (the ones from HD and Lowes are too short) and make your own.
Attached Thumbnails Passenger Peg Bracket Interchange-16907d1397402532-fs-rear-pegs-w-integrated-turn-leds-jardinespacer-jpg.jpg
Old Apr 27, 2014 | 01:45 PM
BlueBirdin'
Should have added, I already checked into that, for the stock ones to work I would need 100mm spacers, at that point I'm cutting tube to length which is ok. However, that is a lot of leverage being placed on the sub-frame and it is not a through welded bung, only half.
Old Apr 27, 2014 | 03:01 PM
Point taken but I've never heard of anyone having an issue with this. Devil, Leovince, Jardine, Mig, Indigo, etc all sold their exhausts with the spacers and longer bolts.
Old Apr 28, 2014 | 07:21 AM
sailorjerry's Avatar
+1
I am currently running Jardine high mounts, with the spacers provided from Jardine and I want to say they are 60mm spacers and I have done 5th gear standups pre loading the front and rear end before hand and I have never had an issue of them feeling unsafe/unstable. Not to mention I weigh 220lbs.
The tubing wouldn't be the best idea IMHO, you would want something that fits the bolt nice and snug so the spacer can't shift any.
Old Apr 28, 2014 | 08:38 AM
FTL900's Avatar
I have exactly the same problem with my 2BR high pipes. The stock footpeg would go thru the center of the pipe, and by the time I shim the bracket mount enough to clear, it's too far out to be viable.
Old Apr 28, 2014 | 09:44 AM
Originally Posted by sailorjerry
+1 I am currently running Jardine high mounts, and I have never had an issue of them feeling unsafe/unstable. Not to mention I weigh 220lbs
+2. I ran the Jardines for several years, and 2 up with my wife. She'd climb on [the bike ] all the time w/ no issues placing all her weight on one peg first. If I had to guess she was 120-130ish. Mine looked just like the picture captain posted.
Old Apr 28, 2014 | 10:18 AM
Really? It's only about 2" out (give or take a little depending on the brand) on each side...From what I've heard & read I'm sure plenty of bikes out there make a passenger spread wider than that.
Old Apr 28, 2014 | 04:26 PM
BlueBirdin'
Ok let's limit this to spacers and stock peg brackets are not an option
Old May 2, 2014 | 09:33 AM
SunsetSuper's Avatar
SunsetSuper is on a distinguished road
I have high mount Jardine's, and have removed the passenger pegs. The spacers are still on the bike, because I haven't bothered to get shorter bolts.
Would they work for you?!
If so, I'm sure we could work out a very good deal!!....Like pay for shipping, (maybe throw in the cost of a drink) and they are yours. I will never use them, and hate having parts sit around.
Avatar picture shows them mounted, if you are interested.
CrankenFine
Aug 20, 2014 08:59 AM
thedeatons
Jul 2, 2013 01:42 PM
Moto Man
Sep 7, 2010 11:52 AM
suejenn
Sep 1, 2010 05:52 AM
captainchaos
Mar 26, 2008 06:22 PM
