Oil Leak
Old Mar 17, 2010 | 06:33 PM
996serrano's Avatar
996serrano is on a distinguished road
Oil Leak
I noticed this today. Where is it coming from? Anybody else have this issue. I read posts that said something about O ring behind the water pump.
Old Mar 17, 2010 | 06:51 PM
comedo's Avatar
If the water pump seal goes, coolant leaks from a weep hole at the front of the crankcase. In later models, a hose was attached to the weep hole. The hose goes to the left side of the bike. Usually the first clue that there's a coolant leak from the water pump is a little puddle of coolant beneath the bike. I can't tell by the photo what the substance is. I'd be inclined to wipe it off and see if it happens again.
Old Mar 17, 2010 | 06:52 PM
RWhisen's Avatar
Former Superchicken Owner
You sure you didn't pick up a little drip off the road?
Old Mar 18, 2010 | 11:43 AM
peterpanic's Avatar
pragmatic anarchist
Hey, that's my girlfriend, be nice!
Old Mar 18, 2010 | 02:13 PM
swordfish's Avatar
wipe it off and keep riding it. if you get it again, see if its coming out of the weephole. if it is, get your impeller seals replaced.
Old Mar 18, 2010 | 06:32 PM
996serrano's Avatar
It is oil by the way. The weep hole your talking about can someone post a pic?
Old Mar 19, 2010 | 05:25 AM
falcondrvr's Avatar
falcondrvr is on a distinguished road
I can't take a pic for you but you're already right in the 'hood of the weep hole. Start from the pic you posted and keep going to the right around the front of the case and the hole will be on a flat surface facing forward.
sparkyharley
Oct 14, 2008 10:53 AM
blacksheep
Aug 22, 2007 09:32 AM
Yardstick
Jun 7, 2006 09:13 AM
mikecronis
Apr 6, 2006 06:08 PM
Natedog
Sep 9, 2005 05:41 AM
