oil in the airbox...?
so with getting a k&N soon as well as needing to fix some things that I've been putting off, I took the thooperhawk apart again. Well I open up the airbox and looky looky, oil in the bottom. Now I had seen small amounts of liquid in the box before but always thought it was gasoline spitting up through the carbs that'd happen whent he carbs would cough. Well this is DEFINETELY oil.... so uh wouldn't the only way that'd happen is if I have bad rings? i really have no clue but it was quite a bit and it's only discouraging me more....
i recently sqitched to synthetic 10w-40 but the fluid had been in there before I switched....
It can be a combo of a couple of things.... First if you got a KN filter, that itself has some oil in it (new and if you recently cleaned it and oiled it), and also don't forget those big breather tubes coming off off the head/valve covers that connect into the bottom of the airbox.... Unless you got puddles of oil in the box, I wouldn't be too worried....
spladle160
Mar 15, 2010 08:42 AM
CNI Dawg
Jan 24, 2008 08:59 PM
