Ohlins shock question
Old Nov 25, 2010 | 07:51 PM
I recently purchased a used Ohlins shock from a fellow forum member (see attached cropped pic) and the bottom mount is rigid. MY question is to other who own such a shock: is there supposed to be movement in the cylindrical insert located in the bottom mount or is it rigid by design? It seems odd to to me that the bargain OEM Showa uses needle bearings and that a premium piece like the Ohlins would be rigid.
Thanks in advance for your help.
Old Nov 25, 2010 | 08:46 PM
trident00's Avatar
trident00 is on a distinguished road
Mine appears to be the same as yours. I dont see any needle bearings etc. I dont know if that metal insert rotates on a bronze bushing or not. Mine seems fairly much set.
Old Nov 26, 2010 | 03:11 AM
bjorn toulouse's Avatar
Destructive Tester
Originally Posted by mikstr
............is there supposed to be movement in the cylindrical insert located in the bottom mount or is it rigid by design?
Short answer: YES, the insert should rotate as it is a pivot point.
Rex
Old Nov 26, 2010 | 10:00 AM
JamieDaugherty's Avatar
Ohlins uses a part that is basically a heim joint. Pull the two collars off and clean/lube the spherical ball until it rotates freely. I have to do this on pretty much every Ohlins shock I rebuild, so it's pretty typical. Pack it full of wheel bearing greese and you should be fine until it's ready for it's next rebuild.
Old Nov 26, 2010 | 12:33 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Oh crap......Just done the same as Mick, bought a 2nd hand Ohlins too. Thought the same question too.
So the bit sticking out both sides is actually 2 bits? And they should come out? Is that the same for the top as well?
Looks like my next job is to pull the shock off again.....
Old Nov 28, 2010 | 04:54 PM
Yes. Yes. Yes.
102dals
Jun 16, 2007 09:09 PM
Randman
Apr 3, 2007 06:11 PM
captainchaos
Sep 20, 2006 05:37 PM
CNI Dawg
Jun 3, 2006 06:03 PM
superbling
May 20, 2006 03:36 PM
