Is this an OE r/r?
Old May 28, 2016 | 06:14 PM
DeLoreanBoy's Avatar
DeLoreanBoy is on a distinguished road
Is this an OE r/r?
Dumb question but does this look factory? It does to me but I was under the impression the factory VTR R/Rs didn't have cooling fins?
I guess there is no way to tell if it's upgraded or not without looking at the back but at least I would know if it was the one the bike was born with. This is a '98 SuperHawk
Thanks
PS: This probably needs to be moved to the correct forum. I screwed up
Attached Thumbnails Is this an OE r/r?-20160528_182242.jpg
Old May 28, 2016 | 07:02 PM
'98-'00 did not come with a finned R/R. Someone will correct me if I am wrong, but '01-'05 got a finned version, but it was not a MOSFET R/R.
Grab a 10mm socket, pull it off the subframe and look at the back. Two bolts and you will have your answer.
Old May 28, 2016 | 10:59 PM
Thanks
Not OEm for that year bike, may not be an OEM one at all, and it's diad in any case so worthy of replacement with a MOSFET
Old May 29, 2016 | 04:06 AM
Thanks all!
Old May 29, 2016 | 05:52 PM
That is from a later model OEM, still diode based, still crappy
Old May 30, 2016 | 12:52 AM
Wicky's Avatar
Don't think so as the fins on OEM 01-05 model run the other way - across rather than lengthways. Unknown aftermarket and as you say still diode based.
Best option is search for FH020AA on eBay.
Old May 30, 2016 | 11:43 AM
+1 You could be right, doe's look similar though
Old May 30, 2016 | 04:16 PM
I just looked back through my old pictures and saw the '01-'05 R/R is how Wicky describes.
Old May 30, 2016 | 05:03 PM
Well , I suppose the BEST option would be the new SHINDENGEN SH847 Series R/R with upgraded wiring. From a DL1000 2015 or newer
RECTIFIER ASSY 32800-31J00
If you're looking for a cheaper solution that has shown to work well, then yes I agree, a good used old style shunt SHINDENGEN FH020AA and good wiring is a MUCH better solution than any of the diode R/R
Old May 30, 2016 | 11:54 PM
Stephan's Avatar
E.Marquez: isnīt SH775 good option as well? Should be series like SH847, but not so robust. I will replace R/R soon and consider FH020 or SH775.
I donīt undestand electric, just know that FH020 will work, but if there can be little upgrade with SH775 for the same price, why not ...
Old May 31, 2016 | 06:48 AM
Yes the 35 Amp SH775 is a great option as well.
The FH020AA or SH775 brand new is $100
