Need 1998 Front flush mount signal advice
Old Aug 27, 2008 | 08:26 AM
lynchie's Avatar
AZ RIDER
OK, im NOT going to buy the melting signals from ebay.. I can cant find any signals from Lockhart for VTR in the catalog..
What flush mounts have been tried and tested and do i need to add a equalizing relay thingy? Somone please post a link i can use with your personal experience with mounting them on your 1998.. i would like to buy them but im going in circles reading all the others posts
thanks
Old Aug 27, 2008 | 08:47 AM
haknslash's Avatar
Many threads on this lynchie. Many of them.
If LED flushmounts is your thing, I would suggest Watsens or Protons. Plenty of info here and on the net about both.
Watsen http://www.watsendesign.com/Honda_Pr.../Honda_new.htm
Protons (you buy the RC51 ones and they will fit the SH fine http://www.bikebandit.com/product/A5476155
Watsens are the most expensive but are the cleanest looking IMO.
The Protons are a nice alternative. Cheaper than Watsens and has a nice 3-mode (strobe, normal rate, fade) feature for the LEDs not found on anything else.
You will more than likely need to buy some load equalizers. I've heard that if you have stock rear turn signals than you can get away without having to add them if you use the Protons. Otherwise you'll defitely need a load equalizer for each turn signal F/R that has been changed to LED. You can pick those up at your local Advanced Auto for $9. Do not pay outragious prices for "fancy marketing" on load equalizers. It's all BS and should not cost you more than $10 EVER.
Old Aug 27, 2008 | 08:48 AM
motojoe's Avatar
Sexual Daredevil
I used the medium/amber(122-9720) Flush Mount IV turn signals on page 173 of the LockhartPhillips catalog. The small one is too small for the hole and the large one doesn't conform to the curve of the fairing, leaving a gap. Hope this helps.
Attached Thumbnails Need 1998 Front flush mount signal advice-superchicken-001-medium-.jpg
Old Aug 27, 2008 | 09:00 AM
lynchie's Avatar
AZ RIDER
Look at these things.. they look like wings on a b52 bomber. No knock on stock for those that have them..but jeez.
.thanks guys
Old Aug 27, 2008 | 09:12 AM
lynchie's Avatar
AZ RIDER
Where did you buy that seat back??!?!?
My wife would love that
Old Aug 27, 2008 | 09:18 AM
sassage's Avatar
pretty sure that's a Corbin seat option to get that...
Old Aug 27, 2008 | 09:26 AM
lynchie's Avatar
AZ RIDER
i think those lockhart are single filament ? And most post have stated dual is what is stock..
Old Aug 27, 2008 | 09:51 AM
haknslash's Avatar
Yes you will need dual filament incandesent, proton LED, or watsen LED if you want running lihgts + turn signals like the stock configuration is.
Old Aug 27, 2008 | 11:33 AM
lynchie's Avatar
AZ RIDER
Well i spoke with LP directly and they said the ONLY Flush Mount IV Medium available w/ Dual Fillament "action" is Iridium color which is LED not bulb... It is running light and flasher
Part Number is #122-9747 Medium Iridium "Dual Fillament" LED signal
New Rely is needed
Part Number is # 122-7515 Relay
He said this is the best fitting and looking for Honda VtR... Period...
I tried to order through him but he needs 40 dollars minimun.. lights are 17 and change and the relay is 10 bucks..
Old Aug 27, 2008 | 12:55 PM
I run the 2-filiment LP Type 3's which are available from Chaparrel for less than $15 for a set of 2. I used dbl-sided foam tape and fabed an aluminum backet plate (also used foam tape) that I ran the screws thru and nuts supplied. easy install but not LED.
Old Apr 12, 2011 | 12:07 PM
hawkproject's Avatar
hawkproject is on a distinguished road
yea its Corbin, have it for my bike
Old Apr 12, 2011 | 01:10 PM
geekonamotorcycle's Avatar
I actually have some really nice flush mounts installed. I will see if I can remove them to find out what brand/model they are as the previous owner added them and not myself.
LotusLand
Jun 27, 2008 06:50 AM
andyeis
Jan 14, 2007 10:04 PM
AKohler996
Apr 21, 2006 11:11 AM
CNI Dawg
Nov 7, 2005 10:37 AM
barrysuperhawk
Jul 16, 2004 06:05 AM
