Cat eye (flush-mount) turnsignals on the front of the SH ?
Old Apr 21, 2006 | 07:34 AM
AKohler996's Avatar
AKohler996
I see a bunch of folks that have them, so they must fit well.
How easy are they to install ?
Do they require cutting or drilling at all ?
It looks like the just have a big round screw-on nut in the back to hold them in.
Old Apr 21, 2006 | 11:11 AM
AKohler996's Avatar
AKohler996
Re: Cat eye (flush-mount) turnsignals on the front of the SH
... another question ... I only see sinle filament versions of this light, I assume I just don't hook up the one wire, and then the fronts will not be lit when the bike is on. This is "probably" not required for DOT anyway, especially with the center marker light.
if this type is not the best type to use, what other flush mount type do you recommend that doe not require modification the the fairings.
I see a company that sells block off plates / adapters for using small stalk signals, but I do not see a listing for Honda.
Alan
reaper
Oct 12, 2013 08:49 PM
8541Hawk
Nov 25, 2011 06:55 PM
VTS
May 24, 2010 04:51 AM
crazybrit
Jun 21, 2007 10:17 AM
Chitownson
Jun 16, 2007 09:15 PM
