milkshake in the coolant reservior
Old Jan 27, 2009 | 10:25 AM
chevy's Avatar
chevy is on a distinguished road
uuuuuuuughhhhhhhhhh!!!!!
fellows, wtf?
Please tell me this is not a blown headgasket, the bike has never been hot, runs perfect, just happened to check coolant and BAM!!!
I have noticed that my right tail pipe runs hotter than the left.
IS THERE ANYTHING I CAN DO AND HOW MUCH APPRX..........
Old Jan 27, 2009 | 10:36 AM
Truckinduc's Avatar
I hate to say it but that is a symptom of a blown headgasket. I know its not the answer you want.
1st check your oil. It should be apparent if there is water in it.
Old Jan 27, 2009 | 10:50 AM
Yes, we have all (on some bike) had to stare down at the dreaded melted ice cream. Usually on a recebike for me but I have never heard of a different interpretation of this symptom. Sorry man, that blows monkey ***, but it is not necisarly a disaster. On my racebike I just yank the valve cover and lap the head flat, then bolt it back together wiht a new gasket. I do it fri night & race on it sat.
Old Jan 27, 2009 | 10:56 AM
RK1's Avatar
RK1
All VTRs pass more exhaust/run hotter through the right can. That's got nothing to do with your coolant or head gasket.
Old Jan 27, 2009 | 01:53 PM
chevy's Avatar
sooooooooo,
at best, what is this going to set me back, could it be anything else besides a head gasket.........looking at the oil through the window looks regular to me, i guess i need to do a complete oil change
would flushing help or it's time to go the the Dr. (shop)
Old Jan 27, 2009 | 02:24 PM
hawxter996's Avatar
ole dirty bastard
drain your oil and report back.
Old Jan 27, 2009 | 05:02 PM
chevy's Avatar
cool
chevy's Avatar
lol
Old Jan 27, 2009 | 05:42 PM
hawxter996's Avatar
ole dirty bastard
findings?
Old Jan 27, 2009 | 05:57 PM
Truckinduc's Avatar
head gaskets are around 30 bucks each at your local honda dealer.
If you can do it yourself you can save ALOT of money, but you better be confident.
Old Jan 27, 2009 | 10:51 PM
Is there any coolant coming out of the water pump weep hole?
Old Jan 27, 2009 | 10:59 PM
Other assumptions made. The kid really owns $100 in tools to work on the bike properly. Has a shop manual and a great place like this to air it out.
Happy Trails
Old Feb 2, 2009 | 11:13 AM
Truckinduc's Avatar
ya man what happened?
Old Feb 3, 2009 | 10:58 PM
Open the radiator cap (when cool) and see if there's floating oil/residue around the opening. Sometimes a little seeps from one place to another through the water pump area. The reservoir tends to collect it since it comes off of the high point on the right radiator. If it's just a little oil I wouldn't be worried. A "milkshake" is different. Finding the source can be challenging, but I would start at the water pump first. It's pretty rare for a head gasket to blow on a Superhawk.
Old Feb 5, 2009 | 05:58 PM
cameron's Avatar
well this brings a question to mind. can you liquid glass a bike with a blown head gasket like you would an old car? not that it is a permanent fix but hey i drove an old vw fox 35,000 miles glassed.
Old Mar 11, 2009 | 03:26 PM
chevy's Avatar
okay, finally i can answer this question.
took off cap and there was not any residue that i could see floating around but i did notice a lil of the milky inside the cap, i took off bottom radiator hose, no milk in the hose or the top radiator hose, only in the resivor, fluid came out with a watery light green color appeared to be real old.
anyway i flushed with prestone and distilled water, and refilled with prestone 50/50 and flushed out the resivor out real good, so far no more milk.
took to the shop before the process and he stated that it doesn't look like a blown head gasket, just dirty, said i would know it it had a blown gasket.
So I guess everything is okay fellows.........ssswwwwhhoooo (hand wiping across face)!!!!!
Old Mar 11, 2009 | 03:31 PM
Truckinduc's Avatar
good news
Old Mar 11, 2009 | 04:14 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
Good news for sure.
Old Mar 11, 2009 | 04:21 PM
FL02SupaHawk996's Avatar
Fastest Color
1 milkshake averted, but have you changed to manual CCTs yet?...LOL
Old Mar 11, 2009 | 04:40 PM
j shizzy wizzy's Avatar
mildly retarded
Glad to hear!! In the future, when you will inevitably need to work on your bike, my advice is to take a ton a pictures with a digital camera as you progress through the project at hand. If you forget what goes where, you can have something for reference! This has helped me a few times working on my jeep.
Old Mar 11, 2009 | 07:11 PM
chevy's Avatar
that will be applied........knowledge is power, and no i have not changed the cct's but that's one of my things to do this spring.
um trying to change the spark plugs now "ngk" but can't find a socket to fit that D#*n hole lol............any suggestions begore getting too far off topic
Old Mar 11, 2009 | 08:21 PM
MLB's Avatar
MLB
MLB is on a distinguished road
Did you check your tool kit on the bike? Don't know, haven't looked, but all the Honda's I've owned before (lots) came with one.
Old Mar 11, 2009 | 10:49 PM
yruyur's Avatar
glad to hear it things turned out ok.
Old Mar 12, 2009 | 07:18 PM
chevy's Avatar
don't have bike tool kit, ask dealer could i just order part ...........he replied i dunno.......asked about kit....um i dunno......i hung up the phone...poor *** customer service
Old Mar 12, 2009 | 10:03 PM
Truckinduc's Avatar
18mm thin wall socket
Old Mar 13, 2009 | 05:30 AM
Fastest Color
tool kit:
http://fiche.ronayers.com/Index.cfm/...66/Group/TOOLS
Old Mar 13, 2009 | 08:12 AM
Billzilla15's Avatar
my 18mm snap-on 3/8 drive fit perfectly. i put NGK iridum IX plugs in mine
Old Mar 13, 2009 | 08:23 AM
chevy's Avatar
Bingo....................
Old Mar 15, 2009 | 06:15 AM
Hawknut's Avatar
Hawknut
I did not see it in the post--but I hope that you did not use regular Prestone.It contains silicate(grit for the most part).Good for scrubbing cast iron blocks but really bad for motorcycle water pump seals.Do a Google search and you will find it mentioned in a ton of forums.Bite the bullet and use the Honda stuff and change it every 2 years.I have 3 Buds that have almost 150,000 mi. on Goldwings and no problems.I have seen pump failures on bikes with non silicate free stuff.Get caught cheattin and it will cost you in the end.http://www.youtube.com/watch?v=g1FBBL73MQM This is why you need to change it every 2 years or so.It becomes acidic and attacks the aluminum.
Old Mar 15, 2009 | 03:24 PM
Dan Cronin's Avatar
<regular Prestone.It contains silicate(grit for the most part).Good for scrubbing cast iron blocks but really bad for motorcycle water pump seals>
Didn't know that about the coolant. Thanks for the heads up.
