LED advise
Old Oct 10, 2008 | 07:03 AM
Byrdman's Avatar
Super Byrd
LED advise
Im wanting to go all LED turn signals, but not sure what to get. Do i have to get one resistor for each turn signal or can i buy one relay for all the turn signals?
will the relay from LP work? and if so, how many do i need?
any advise would be greatly appreciated
Old Oct 10, 2008 | 08:25 AM
Erik S.'s Avatar
Replace the flasher is the easiest way, or leave them and have the faster blink rate, which in my opinion calls more attention to you and makes you more visible.
Old Oct 10, 2008 | 02:56 PM
I put led's on my previous bike and did need a resistor for each signal.
Old Oct 10, 2008 | 04:36 PM
Moto Man's Avatar
Duc Hawk
I swapped out all my signals with LED units and did not put any resistors in or mess with the relay. It just blinks faster wich is not that bad IMHO. Try it first and then if you think you want it to be slower add a resistor later to the lft and right circuits. You will only need 2 resistors and they can be wired in parallel to the LED lights.
Old Oct 10, 2008 | 06:54 PM
armyguy8381's Avatar
armyguy8381 is on a distinguished road
I agree I like mine blinking faster.. Brings more attention to me. Just my .02 worth.
Old Oct 10, 2008 | 07:22 PM
Scoutpilot's Avatar
I put on Proton flushmounts that are programmable. On the tail, I've got LED brake like and LED flashers in the undertail. They don't have resistors on them but I replaced the relay from one at CG that made them blink at the normal rate. The relay was only about 20 bucks.
Old Oct 10, 2008 | 09:16 PM
Byrdman's Avatar
Super Byrd
whats the link to that or the manufacturers name? thanks
Old Oct 12, 2008 | 08:33 AM
Blue Ridge Boy's Avatar
Proton is the company. They retail for $99. If you have a local bike shop that uses Tucker Rocky they can order you a set. If not, there a few websites that carry them such as PowerSportsStore and IndySuperbikes.
Old Oct 13, 2008 | 11:55 AM
Byrdman's Avatar
Super Byrd
i was actually talking about the relays, but thank you
Old Oct 13, 2008 | 02:07 PM
Verne's Avatar
Verne
I have all LED's and am running a Custom LED flasher relay. Plug and play application. Works great but if you have one go out it will not change flash rate but what are the odds of a LED turn signal going out. They sell them on eBay or off their site.
http://www.customled.com/PRODUCTS/FL...sher_relay.htm
Verne
Old Oct 13, 2008 | 02:41 PM
Verne
Less likely than the relay failing...
Old Nov 2, 2008 | 05:51 AM
dsevans's Avatar
dsevans is on a distinguished road
resistor for turn signals
Hello,
Does anyone have a pic and/or description of the specs and how they wired it up to slow the rate of the signals flashing? It is odd, only my right side (front and back) flash quickly. The left is normal.
Thank you.
Darren'
Anto
Sep 12, 2009 11:47 AM
Anto
May 5, 2009 05:20 PM
2000superhawk
Oct 31, 2006 05:38 AM
Racer647
Aug 21, 2006 10:22 PM
