Kickstands
Old Nov 3, 2010 | 11:33 AM
Old Yeller's Avatar
Kickstands
My kickstand seems short and the bike really leans over when parked. From pictures, it looks like others do to. Is it normal for everyone?
Old Nov 3, 2010 | 03:18 PM
U raise the read ride height with a shim or longer AM shock & raise its RH? Cranking up the OE shock spring preload only won't do it
Old Nov 3, 2010 | 04:29 PM
comedo's Avatar
Raising the forks in the triple clamps will reduce the amount the bike leans while on the sidestand as will having a full tank bag and tailpack. However, raising the forks will affect how the bike handles.
As long as the sidestand is not bent or damaged and the mounting plate and pivot bolts are tight, I wouldn't worry about it.
There was a fair bit of play at the kickstand pivot on my VTR. I reduced it with shims.
Aside from that, the only sidestand issue I've encountered occurred when the rear tire was punctured and deflated. The bike could not be supported by the sidestand. With the sidestand down, the bike was past vertical and leaning toward the brake side. I had to find a small depression to put the foot of the sidestand in so the bike wouldn't fall over.
Old Nov 3, 2010 | 05:20 PM
CANADAVTR's Avatar
CANADAVTR is on a distinguished road
I found that my VTR leaned over too much. I ordered a new kickstand - about $30 OEM, and it was a ton better for it. Turns out the old one had a slight curve in it (when I compared the two)....
Old Nov 3, 2010 | 07:04 PM
Just to be clear, you agree raising the rear makes it lean Port side alarmingly. Forged steel OE footpeg is relatively malleable; i.e., it does not take much force to try to restore the pivot slot width. But it will loosen again. Shims are doable as you indicated. I thought it was a given the OE footpeg was near spec.
Old Nov 3, 2010 | 08:11 PM
hondavtr1000sp2's Avatar
Not normal for me, my bike does not lean over much.
Attached Thumbnails Kickstands-2009-04-13-16-56-49_0086a.jpg   Kickstands-2009-06-12-11-20-32_0042a.jpg
Old Nov 3, 2010 | 09:41 PM
saige's Avatar
the boss
i like the idea of this,dont think i like the price so much.
http://cgi.ebay.com/ebaymotors/VTR10...Q5fAccessories
Old Nov 3, 2010 | 09:56 PM
Wow that is complex and expensive for a kickstand- may as well anodize it and carve VTR into the side if you're doing that much
Or stud it with diamonds in she shape of "$" or "BOSS" or something like that
Old Nov 4, 2010 | 05:08 AM
besides, it goes from stock length to shorter, nothing to fix the problem there....
Yep, we need someone to get working on a nice lightweight (and slightly longer) billet kickstand......
Old Nov 4, 2010 | 07:07 AM
comedo's Avatar
Dear Skokievtr: I agree completely that raising the rear will cause the bike to lean more when it's on the sidestand. I thought my bike was too close to vertical when everything was stock and though I shimmed the shock to make it easier to turn a happy side effect was the increase in the amount the bike leaned when on the sidestand.
Dear Mikstr: A lighter, prettier side stand would be nice. The main reason I would be slow to buy one is that when I'm on a trip, I'll ask a buddy to pull the bike toward him so all the weight is on the side stand and front wheel and the rear wheel is off the ground so I can rotate it as I lube the chain. I'd be concerned that the side stand might bend or break if it were made of a weaker material than the steel used now.
Old Nov 4, 2010 | 07:11 AM
nothing's Avatar
ride it out
I have an extra in great/oem condition hawk kickstand for sale if anyone needs!
Old Nov 10, 2010 | 08:56 PM
Yeah, I would worry about anything weaker than stock. The great thing about this bike is that you can "pole flip" it by grabbing the frame just by the subframe with your right hand & pull & the whole bike can easily balance on the sidestand alone & you can spin it around to park it. I can barely do this on other bikes but on the VTR it saves alot of stupid adjustments. You can leave it where it is & just flip it 180* & ride off the other direction.
Old Jul 25, 2011 | 09:53 AM
Old Yeller's Avatar
Reviving an older(ish) thread.
Has anyone come up with a solution for a longer kickstand? The only option I can see is to weld in a 2 inch insert. Any other thoughts???
Old Jul 25, 2011 | 10:10 AM
PUSHrod's Avatar
Solved two problems with one solution. That of the excessive lean because of suspension changes and that of the foot of the side stand punching through soft asphalt in the Florida sun-baked parking lots.
Hockey puck. Drilled a hole through it for a retrieval string, when under the foot of the side stand the bike is at a more reasonable angle and is in no danger of sinking into the pavement. Also, the string allows me to retrieve the puck without bending over (the other end of the string has a clothespin to clip it to the clutch lever).
Gotta love lo-tech and free in this world of solutions looking for problems.
Old Jul 25, 2011 | 12:07 PM
Old Yeller's Avatar
I'm old-school. I did it with a piece of wood.
I found a little spot in the fairing beside the speedo housing to put it while riding.
Old Jul 25, 2011 | 03:25 PM
Yeah, my steel plate solved it, and it can easily be switched to stock it needed.
Old Jul 25, 2011 | 04:08 PM
Is that corrosion I see on that chain??
Old Jul 25, 2011 | 04:35 PM
speedkelly@aol.com's Avatar
Wood block
Yep, same thing here. Block of wood for the side stand. I think if you shim the back you pretty much have to?
Quick question? do you guys know if the ohlins rear shock is a little longer than the stock honda item?
Old Jul 25, 2011 | 05:55 PM
Heck no, its a gold chain. The pipes a little ridden though.
Old Jul 25, 2011 | 09:33 PM
Old Yeller's Avatar
Excellent. thanks Joe!
Old Jul 26, 2011 | 08:26 PM
CrankenFine's Avatar
+1
Since adding spacers to the top of my shock, my bike leans further than before.
Level ground is like unobtanium around here, so a little piece of plywood increases the lift of the stock sidestand just fine.
Old Jul 27, 2011 | 05:21 AM
Old Yeller's Avatar
Did the extension plate last night. worked like a charm. Anyone with the problem should consider doing it. it beats carrying around a block of wood.
A few things of note. First, one of the bolts is part of the motor mount and goes all the way through under the motor. Second, my shift arm was in the way so I removed it to make the job easier. Third, as part of the plate fab, you have to cut a small relief section at the bottom center to allow space for the kickstand bracket to mate up to it.
Old Jul 27, 2011 | 07:52 AM
Nice, Yeller. Now that I have an angle grinder/cutter, I may have to try this. Gotta find some decently thick metal, as I like to do the kickstand pivot a la smokinjoe. I think he had problems with too thin of metal before...
Old Jul 27, 2011 | 10:11 AM
Old Yeller's Avatar
the piece of metal I used was not particularly thick and I'm keeping an eye on it. However, from initial inspection it seems that the kickstand itself has more flex than the plate. The good thing about the plate is that there is very little distance between bolts so I don't think it has the stress of the stand itself.
Old Aug 2, 2011 | 10:05 AM
Old Yeller's Avatar
well, so much for my fix. My initial piece of metal stock was not thick enough and last night while I was in the garage working on the Concours the kickstand gave out and the plate bent. I replaced it with 1/8 inch stock steel I had sitting around. It gave out on the garage floor because of the relatively slick surface that allowed the stand to spread out too wide.
The aftermath included a cracked tail section because it landed on the footpeg of the concours. It also bent the shifter linkage which broke in the process of trying to straighten it. Fortunately I had some spare track backup parts to put things back together. I'll be needing a rear section though, because my track plastic is pretty beat up.
Old Aug 2, 2011 | 11:12 AM
msethhunter's Avatar
Huh. My problem seems to be the exact opposite. I don't think mine leans over far enough, to the point I am limited on the angle of the surface I can park on.
Old Aug 2, 2011 | 11:46 AM
Old Yeller's Avatar
have you lowered things? In my case, mine stands taller because I have the forks lowered in the triples....which makes the front end taller and slows the steering a little, and have the rear shimmed about 5 mm. those things raised the frame enough that the kickstand is not long enough and it leans over too far.
Old Aug 2, 2011 | 12:57 PM
I raised the forks in the tripples a few mm's. But that shouldn't do anything signifigant.
Old Aug 2, 2011 | 08:52 PM
Old Yeller's Avatar
is it lowered at the rear shock mount or something? It's rare that I've heard anyone say the kickstand is too long.
Old Aug 2, 2011 | 08:56 PM
Old Yeller's Avatar
by the way....1/8 inch steel gave way on me again after I got home from work today. I've now made another bracket from 1/4 aluminum that I had in the garage. If this doesn't work, I'm going to have to get more creative with a piece that has an angle to strengthen it more. it's only happened to me in the garage where the kickstand more easily slides on the smooth concrete.
