Impressed!!!
Old May 2, 2012 | 11:37 PM
  #91
chemomche's Avatar
chemomche is on a distinguished road
I can not understand why you argue at all.
The speedo always show more than the actual speed. So you think you go faster, you think your car/bike has better gas milige, you drive slower because you thing you drive faster....
All the vihicles i have drive/ride show 5-10% less on the speedo compare to the GPS. A couple of weeks ago i tried my Hawk - put the GPS on and go for 200 on the speedo(km/h not miles) and the GPS showed top speed 188km/h. Same did my little Peugeot on the highway. Stock gearing, stock tire sizes.
And about the tire slip....if so the rear tire/front sprocket reading is no accurate, but what would you say about front tire readings?
My ex bike - GSX750F Katana had cable speedo connected to the front tire and guess what it showed 10% less than the actual speed -confirmed by many of the Katriders forum.
Old May 17, 2012 | 04:34 AM
  #92
splatranger95's Avatar
splatranger95 is on a distinguished road
Originally Posted by GTS
Yeah I get what you're saying. To bad there aren't any Honda engineers on this forum that could shed some light on the subject!
Funny you should say this because I actually Am an engineer at Honda! HAHA. Seriously though, Im an Electrical Engineer at Honda. The speedo and the ODO use the same signal. The reason the ODO and speedo are not both spot on is the speedo is not digital. Any analog gauge will never be as good as digital. Both the speedo and the ODO are calculated with the same signal and basic formula as well.
Speedometers are given a % from the govornment that they are allowed to be "off" and car companies try to make them accurate, but honestly for the $.01 per car price difference, honda speedo's are usually off by about 7%. Older Honda speedo's used to be off by much more till they were taken to court over it. Tire slippage at 150+mph will come into play, but not as much as 30mph.... Thats just plain too much. The bike would wobble all over the place. Most of the inaccuracy of it is from the analog speedo just being an old piece of technology that wears out and since the numbers are so freaking close to each other anyway, you will never be able to "accurately" see your speed with your eye. You will have to use a gps. I dont want to fuel a fire, but that is literally what I do here at Honda, so I wanted to clear a few things up.
Old May 17, 2012 | 05:07 AM
  #93
rz_racer_69's Avatar
Old and dangerous
Thanks for your input. That is a great explanation why our odometers are accurate (with stock gearing and rear tire size) and our speedometers are optimistic by a consistent ~7%. My question now though, is on the later models with the digital speedos, why is the speedo still optimistic? Or is it?
Old May 17, 2012 | 05:51 AM
  #94
RWhisen's Avatar
Former Superchicken Owner
My 02 was off by 4%-5% throughtout the range. Corrected with a SpeedoHealer.
Old May 17, 2012 | 07:49 AM
  #95
Good explanation and I respect what you do but I do have a couple of points to add in.
First I guess you either didn't read the whole thread or misinterpreted some of it.
The whole 30mph of slip was a figure thrown out buy someone who admitted they were "rounding" the numbers up in order to support their side of the discussion.
So while you are an electrical engineer, the 10% of tire slip (or 15mph @ 150 mph) was given to me by the chief tire engineer at Dunlop and I respect what he was doing also (as he is now retired)
Also my '98 is off by 4% and has been checked many times.
Old May 17, 2012 | 08:51 AM
  #96
RWhisen's Avatar
Not the &^%$#)(*!@# tire slip thing again. Are we going to pull out best oil types and ideal sprocket sizes next just to complete the trifecta?
Old May 17, 2012 | 09:18 AM
  #97
Sorry if I awakened a sleeping tiger. I just noticed the thread and thought maybe I could shed some light. Digital speedos should be pretty correct. At least in our auto's they are. 1%-2% error usually and that is because of the rounding in the ECU to account for ever changing road conditions as well as the Analog to Digital conversion. Proper tire inflation, chain and sprocket wear has a tiny effect as well. Our new cars actually use GPS for a speedo signal too. Honda is not the only manufacturer doing so either.
Old May 17, 2012 | 09:28 AM
  #98
No no, we need something that's actually definitive.
Yellow = Fastest.
Old May 17, 2012 | 09:30 AM
  #99
RWhisen's Avatar
Sorry if I awakened a sleeping tiger..........
I was just being a smart ***. We do appreciate the input!
Old May 17, 2012 | 09:51 AM
  #100
At least you got a reply to your post.......
Old May 17, 2012 | 10:09 AM
  #101
RWhisen's Avatar
It's not what you say, it's how you say it!
Old May 17, 2012 | 10:22 AM
  #102
Guess I need to use some of these !@#$%^&* next time....
  #103
GTS's Avatar
GTS
Seasoned tech
Splatranger95 Thanks so much for the input! That's good to know. Also it's good to know we have someone on here from Honda that knows their systems and can probably be an invaluable source of information on this site!
The true top speed of a SH in in the 155-159 range. At these speeds the speedo will be buried well past the 180 mark.
It will tell you that the bike is capable of a 183 mph top speed but the leave out tire slip.
Sorry, based off YOUR comment I rounded up by 3-5 mph.
Old May 17, 2012 | 10:32 AM
  #104
RWhisen's Avatar
Yellow = Fastest.
You're right, Yellow = Fastest is certainly NOT definitive when we all know RED = Fastest!
Nevermind........
Old May 17, 2012 | 10:41 AM
  #105
Now that is just funny..... because the way I read it is that YOU manipulated numbers and posted inaccurate information in order to try and prove You had to be right and it's all MY fault that you did so....
Roll your eyes all you want but damn....
Old May 17, 2012 | 11:05 AM
  #106
Nevermind........
Now thats funny. I bought a black one, because I have a mangina and wont go over 90. I like my life and dont feel like dying... Black = low and slow. (and loud with the jardines...)
Old May 17, 2012 | 11:17 AM
  #107
RWhisen's Avatar
Since you're the Honda engineer and have knowledge about such things, it has been rumored that extra deviation was intentionally programmed into yellow Superhawk speedometers to introduce the euphoric feeling of speed when ridden by their gullible owners. I understand that this may be proprietary information and you may not be able to confirm or deny however you could offer a few words of consolation to the owners of the yellow Hawks.
Seriously, cool to have you around and can't wait to see the bantering 'tween you and Tweety. We have a few well documented issues with the bikes and between most of us here on the forum we've seen it or heard of it. Have you changed your R/R and CCTs yet?
Old May 17, 2012 | 11:21 AM
  #108
CrankenFine's Avatar
No, better yet, I propose we revive the debate about whether swallows carried coconuts to England...
Monty Python and the Holy Grail (1975) - Memorable quotes
Old May 17, 2012 | 02:39 PM
  #109
GTS's Avatar
GTS
Seasoned tech
There is a very simple explanation to that as proven by you in the CCT thread. You don't actually read what's being typed. You skim over it and fill in the blanks in your head then fire off rebuttals to things that were never said.
A simple suggestion would be to take a few deep breaths, count to ten, calm down and actually slow down and read what’s being typed BEFORE you rebut, that way you A) don’t look silly arguing with yourself and making claims that someone said something they never said, and B) would figure out that I was agreeing with your theory, just not how much, which was also proven different from research from a major suspension company called Ohlins.
Old May 17, 2012 | 04:29 PM
  #110
1st of all... I think I've "heard" rumors of yellow hawks being absurdly biased as far as speedo readings.. But I've also "heard" Red ones come with a ***** installed in the seat for owners comfort. Seriously Im just Just kidding... Im new here and I shouldnt joke like that till I get to know people.
I have not changed the R/R or the CCT. I was debating the CCT's but I wasnt sure how big of a deal it was. I know they are plastic (??) but do they fail? I have had many honda's and have never had the R/R fail. Is it really common with the Hawk?
Old May 17, 2012 | 04:51 PM
  #111
wsharpman's Avatar
99 superhawk
yes very common for r&r to go bad... swap it out for a r1 mosfet r$r as soon as possible. Mine failed within weeks of owning the bike. As for the cct's I cannot say as mine hasn't gone bad in the many miles I have put on the bike, however it has been niggling at my mind and my to-do list, just a bit unsure about the process lol.
Old May 17, 2012 | 05:50 PM
  #112
RWhisen's Avatar
1st of all... I think I've "heard" rumors of yellow hawks being absurdly biased as far as speedo readings.. But I've also "heard" Red ones come with a ***** installed in the seat for owners comfort............
No wonder I can't get your girlfriend off my bike! She says it's much better endowed than her nerdy engineer boyfriend......
I can't tell you how many times I've read the "I never thought it would happen to me" CCT story. There are a couple new examples floating around the board now.
Old May 17, 2012 | 06:00 PM
  #113
Well its nice to know the people around here like to joke. That was a good one. My other forum is great like that too. Well i suppose Ill start to look into the CCT. Do you recommend anything? stay automatic or go manual adjust?
Old May 17, 2012 | 06:04 PM
  #114
RWhisen's Avatar
The Trekkie forum? LOL
Seriously, manual CCTs to replace the automatic ones. Read about the failures. It really jacks up your engine!
Old May 17, 2012 | 07:22 PM
  #115
You're a joke dude and yes I will just ignore you from now on..... you state that you rounded the numbers up (which is manipulating the data), so I commented on how funny that is to me and you go on another rant
So maybe you should follow your own advice.....have a nice life
Old May 18, 2012 | 05:30 AM
  #116
PLEASE! Between you two it's a battle royale to get the last word in. Just STOP.
8541:
Fair warning....TO BOTH OF YOU!!!!
Old May 18, 2012 | 08:34 AM
  #117
GTS's Avatar
GTS
Seasoned tech
Wow Hawk, who's the joke? Grow up and grow a thicker skin. Even the experts are wrong sometimes. Deal with it.
Old May 18, 2012 | 09:51 AM
  #118
Well that got you 3 days off GTS. Anyone else?
I personally don't care who is right or wrong. If I could, I'd add you both to each others ignore list. Try it, it works.
Old May 18, 2012 | 12:45 PM
  #119
RWhisen's Avatar
First official timeout that I can remember......
Don't ban me bro!
Old Jun 2, 2012 | 12:14 AM
  #120
tractor's Avatar
tractor is on a distinguished road
wow
remarkable thread.i have read it twice now and its rather interesting.it would also be a relief to get an agreed outcome...conclusion.
on another note hawk do you mind me asking who ned dohen might be??
