How Much to Put Into the SuperChicken?
Old Jan 23, 2015 | 07:29 PM
calirodan's Avatar
calirodan is on a distinguished road
I bought this bike for $2K many years ago, but got a little loose and fast with the clutch and dumped it pretty good. I never even made it out to the highway (which is probably a good thing!). After that, I put about another $1000 or so in parts to fix her back up to look presentable, but then let the bike sit for a few years without riding due to "life".
Recently I pulled off the carbs for a thorough cleaning, and even got her running for a bit for a short ride, but now there seems to be a loud knock coming from the engine (valves, maybe?). Also, keeping the engine running without it puttering out is becoming more and more difficult.
Because of work, I have less and less time to work on the bike now. Would it be worth taking it to a bike shop to get it rideable once more, or should I call it a loss and just buy a new bike? It'd probably need a whole lot of work done (it's a 98), and I'm just trying to poll to see if the juice would be worth the squeeze. I've never truly gotten a chance to enjoy what this bike had to offer.
Old Jan 23, 2015 | 07:48 PM
1971allchaos's Avatar
Where are you located?
Old Jan 24, 2015 | 07:01 AM
calirodan's Avatar
Just moved to VA from San Diego
Old Jan 24, 2015 | 07:17 AM
hawxter996's Avatar
ole dirty bastard
part it out.
post pics and prices.
start anew.
eta.....you sound like a navy man.
Old Jan 24, 2015 | 07:41 AM
Could it have a broken CCT with the timing off a tooth? Worth checking out. If it runs and the knock isn't coming from the bottom end, seems like a fixer to me.
Old Jan 24, 2015 | 11:03 AM
calirodan's Avatar
This very well may be the case.
Old Jan 24, 2015 | 03:36 PM
Big_Jim59's Avatar
Let me give you some perspective. I bought a Superhawk with a knock, thinking it was a CCT issue. I was wrong. It has a bad big end. I have the time to put into is an i have a place to work on it. Even so it is going to be a huge job. If you want to ride, go get yourself something to ride and part this one out to help pay for it.
Jim
Old Jan 24, 2015 | 03:45 PM
Might want to confirm it's a major issue like a rod bearing first.
Old Jan 24, 2015 | 07:22 PM
Big_Jim59's Avatar
This is true.
Old Jan 24, 2015 | 09:48 PM
calirodan's Avatar
Jim
What'd you do to rule out the CCT? Did you put on a manual one and still got the knock, or was there a better way to rule out the automatic CCT first?
Old Jan 25, 2015 | 12:24 PM
Big_Jim59's Avatar
I went the full route and checked both top ends and installed the manual CCTs. I found it strange that nothing was amiss and that the timing and the tension was normal. I buttoned it up and it still made the knock. Now it's down to the crank.
I am a little unclear as to what happned to your bike originally. You said ". . . got a little loose and fast with the clutch and dumped it pretty good. I never even made it out to the highway." I am concerend because I think what knocks the rode bearings out of these bikes is miss shifts. That's a lot of rotating mass to take past red line. On mine I see no sign of oil starvation (shows up in the top end first) and what I do see looks normal for a good engine.
Old Jan 25, 2015 | 08:04 PM
calirodan's Avatar
I was very inexperienced and kept stalling out at stops. One time I went well past the clutch 'friction zone', putting it up on one wheel (PO did the same thing, so maybe an issue with the clutch, but more likely we both didn't respect it enough). When the front wheel landed, I 'death wobbled' into the oncoming traffic lane and hit a stopped car. The bike suffered bent forks, destroyed fairings (of course), bent radiators, and a few other visually minor damages. It's been 'rideable' after some of the major safety issues were addressed, but it sat for a long time due to it not being my primary motorcycle. I think out of everything, the 'sitting' in storage and overall lack of TLC is what caused the most damage. The 'knock' is new after replacing the battery and cleaning the carbs, and sounds like a bolt if it was in the dryer.
Old Jan 26, 2015 | 07:22 AM
Big_Jim59's Avatar
Wow, "a bolt if it was in the dryer" is a new one on me. Check your CCTs before you do anything else. My rod knock was a solid thunking like someone tapping on the inside of the block. A rattly noise usually indicates chain.
Old Jan 26, 2015 | 07:31 AM
Maybe it sounds like a "cam chain tensioner if it was in a dryer".
Old Jan 26, 2015 | 09:04 AM
Big_Jim59's Avatar
I don't know. My wife frowns on bike parts in the dryer.
Old Jan 26, 2015 | 09:18 AM
calirodan's Avatar
Zero was good enough to PM this to me, do I posted it here because he was unable. Thanks, Zero!
Originally Posted by ZERO
CALIRODAN, My "optinet" security here at work wont let me reply to your post. So I'm doing it this way. An engine wont develop a bad crankshaft sitting parked. Something happened while you had it apart, either the carbs are not correctly cleaned and the bike is knocking due to it running very lean, if at all on one cylinder.(My guess) These engines sound almost normal running on one cylinder. Or one of the tiny phillips screws from around the carb fell into the engine? If you're sure that nothing fell inside, Pull the carbs back off and clean them correctly or have them cleaned professionally. This new fuel leaves HORRIBLE crap behind when it sits around! While in there, change your spark plugs in case one is fouled. It would have been easy to foul a plug if you tried to start it before the carbs got new fuel in them. Many times a dead cylinder or a misfiring cylinder will sound like a mechanical issue. Good luck.
Old Jan 26, 2015 | 09:44 AM
calirodan's Avatar
Okay (boy, sounds are tough to describe!), I should've mentioned that the "bolt in the dryer" sound would be in a dryer full of clothes; that is, it's not a continuous "thunk"...only every few seconds. Kind of like if loose change has come loose in a full dryer load. Except it's heavier than if a coin was hitting...more like a nut or bolt, but a solid, single "thunk" or "clunk" spaced out every few seconds or so. Sorry I wasn't more specific before.
Old Jan 26, 2015 | 10:30 AM
CrankenFine's Avatar
That sounds like a carb slide slamming shut due to weak idle. I agree with ZERO ; look carefully for evidence of carburetors still being not clean enough, fuel contamination and spark plug issues. Also consider synchronizing the carbs again.
Old Jan 26, 2015 | 10:36 AM
In my experience, a bad rod bearing is a continuous, periodic knock that varies with RPM. Sounds like a fixer to me.
Old Jan 26, 2015 | 12:47 PM
Big_Jim59's Avatar
That has always been my experience too. that's why I was in denial about my engines bottom end problems. It was rhythmic and regular, no rattle, just tapping.
Twin Kat
Motorcycle News
Feb 26, 2010 08:39 PM
ImitationCrab
Nov 20, 2009 03:26 AM
merlyn
Apr 23, 2009 09:23 PM
Gtrain00
Jan 12, 2009 09:38 PM
Tempest
Sep 5, 2006 11:33 AM
