How do you get the passenger seat uncovered?
Old Sep 26, 2008 | 12:29 PM
MLB's Avatar
MLB
MLB is on a distinguished road
Didn't get a manual. How does the plastic cover come off? I carefully pulled up all around to try to see, figured it was velcro, but couldn't see anything and don't want to break it!
Thanks!
Old Sep 26, 2008 | 12:30 PM
drew_c14's Avatar
yep. Should be two screws, just take the seat off and flip it over.
Old Sep 26, 2008 | 12:43 PM
BatBike13's Avatar
BatBike13 is on a distinguished road
Just pop off the seat and flip it over, there are two clips that lock the solo cover onto the seat, spread them just enough to slide the cover back and off...careful, if you try to spread them to far w/out sliding it off, you'll break the clips and be bummin'
Old Sep 26, 2008 | 12:46 PM
StoneJrW's Avatar
StoneJrW is on a distinguished road
+1
Old Sep 28, 2008 | 12:00 PM
MLB's Avatar
MLB
So does "pop off the seat" mean removing bolts first? I'm not seeing how the seat comes off.
Old Sep 28, 2008 | 12:02 PM
rnb's Avatar
rnb
rnb is on a distinguished road
Use your key at taillight. Pull up and back on seat to remove.
Old Sep 28, 2008 | 01:33 PM
MLB's Avatar
MLB
THANK YOU!
And what the H are the rest of you talking about?
Old Sep 28, 2008 | 03:40 PM
LineArrayNut's Avatar
I could ride in
Originally Posted by MLB
THANK YOU!
This post should make it clear: https://www.superhawkforum.com/forum...ad.php?t=10950
But you pretty much have to read all of it...
Old Sep 28, 2008 | 10:53 PM
THANK YOU!
Well, sometimes we don't get directly to the problem or it's solution.
Old Sep 29, 2008 | 10:42 AM
sassage's Avatar
smartass
Old Sep 29, 2008 | 10:50 AM
rbrais's Avatar
Take off the two nuts that attach the cover to the underside of the seat. Carefully spread the tabs to slide them past the seat hooks. If you spread too much, you can crack the cover. Don't even bother putting the nuts back on when you decide to put the cover back on. The tabs hold it just fine without them.
Old Sep 29, 2008 | 01:11 PM
jbaxx's Avatar
Honducati
Refer to aforementioned post-whoring newbie thread. It's all covered in great detail......
mtbdude91
May 20, 2014 04:03 PM
tomzxt
Apr 16, 2012 12:45 PM
Crashrat
Aug 25, 2010 09:20 PM
cliby
Aug 19, 2010 07:06 AM
plan9
Oct 5, 2006 03:18 PM
