How do I drain the carbs?
Old Mar 16, 2010 | 12:04 PM
CentralCoaster's Avatar
I need to drain old gas out of my carbs.
The bike doesn't run, so running it dry isn't an option.
Old Mar 16, 2010 | 12:13 PM
poppazuti's Avatar
Head Scratcher
take a long flat blade screwdriver and open the drain on the bottom of the bowls. It's a little nipple on the very bottom of the carbs. Right side is easy to get too, the left side sits a little further inboard.
Old Mar 16, 2010 | 12:21 PM
RK1's Avatar
RK1
If you don't want to make a mess, fit some tube/hose over the nipple on the underside of each float bowl and route it into a container on the floor/ground. Open up the screw on the lower outboard of each float bowl.
Old Mar 16, 2010 | 12:22 PM
This is correct though a bit confusing. The drain screw is on the side of the float bowl and it drains out of the nipple on the bottom.
Old Mar 16, 2010 | 12:26 PM
poppazuti's Avatar
Head Scratcher
Agreed...didn't think to mention that. Mine is having a fuel feed issue so I didn't have a tremendous amount of fuel in the bowls, but it was enough to still make a mess. Also worth mention is the screw only needs to be cracked open a few turns, not completely removed.
Old Mar 16, 2010 | 02:18 PM
zmaniv's Avatar
Hey Kevin if you want to we can find a way to get your bike to Mike at Full Throttle and work on it there.
Old Mar 16, 2010 | 02:42 PM
peterpanic's Avatar
pragmatic anarchist
Turn bike upside down? sorry, had to.
Old Mar 16, 2010 | 02:53 PM
+1
I use a 3/16" wide by 8" long screwdriver and extra long "stork" needle nose pliers to slip a hose on the drain nipple.
If your gas is that old, you probably need to clean the carbs too. Since new my bike has never gone more than 7 days or so without being ridden. Last Saturday I started running on one cylinder, limped home and found #2 was dead. Spark was good, so I pulled the carbs (a lot of fun). The slow jet in #2 carb was completely plugged. I had to soak it in carb spray for about 30 minutes to clean it out completely. Then blew everything out with carb spray and compressed air.
I'm looking for some small membrane type filters that will fit under the tank.
Old Mar 17, 2010 | 08:10 PM
Don't scare me like that. My other bike is already apart for the same reason, previous owner didn't ride it, carbs were completely disgusting. Sad because I sold it to him in perfect working order a year prior. At least I got a good deal buying it back from him.
Old Mar 17, 2010 | 09:33 PM
Thanks! I just drained it out onto the floor. Didn't feel like cutting my hands up trying to get a drain hose on there. It was pretty obvious when looking at it, I just posted from work so I didn't have the bike in front of me.
Old Mar 17, 2010 | 09:41 PM
That works...just don't light a cigarette immediately after draining.
Old Mar 17, 2010 | 10:11 PM
RK1's Avatar
RK1
I use a pair of medical forceps to slip tubing over the drain. I imagine needle nose pliers or vice grip would work. Otherwise you can do it outside and use a hose to rinse the gas off the bike and ground. I like to drain to a container so I can check for water, gunk, debris etc.
Old Mar 17, 2010 | 10:33 PM
The "stork" needle nose pliers I mentioned were first sold by Snap-on about 25 years ago. They're about 12" long to reach into very narrow deep openings. I bought a pair of Chinese knock-offs last year from Kragen for about 12 bucks. The first time I used them was to drain my carbs. It took no time at all to snake a length of vacuum hose in there and push it up onto the drain nipple. A good addition to your toolbox.
I'm aware of other uses for medical forceps from my younger days.
Old Mar 17, 2010 | 11:30 PM
RK1's Avatar
RK1
Me too. Before I discovered the value of a cheap corn cob pipe and a 2"X2" square of Reynolds wrap poked with a finishing nail or sewing needle!
I bought the forceps at the Del Mar gun show in 1995 for $2. Also great for slipping tube over the front cylinder vacuum nipple when syncing the carbs and for removing splinters from my hands. Just might be the best two bucks I ever spent.
Old Mar 18, 2010 | 05:26 PM
I prefer to fill the garage with gas fumes, close the door, and then relight my water heater pilot.
muaddib
Dec 17, 2008 08:34 AM
California69gs
Feb 6, 2008 01:19 PM
CNI Dawg
Jan 24, 2008 08:59 PM
vtrguy
May 13, 2007 08:45 PM
mikecronis
Jun 10, 2005 12:59 PM
