great deal on LED's
Old Apr 14, 2009 | 06:04 AM
vermontzx6r's Avatar
hardened stihl
vermontzx6r is on a distinguished road
great deal on LED's
Hey- before you say "Not another turn signal thread!!! DO A SEARCH!" - check these out.
http://www.d2moto.com/Image.aspx?URL...S103-Amber.jpg
I got this promo email from D2Moto- the signals look nice- front facing, LED. I think I'm going to get a pair. I figured I'd post just in case anyone else was in the market. I'm not sure if they come with any additional housing but I figure a little creativity will solve any mounting problems.
I emailed them to ask if they are just signals or also running lights (1 or 2 phase). Not sure if they'll require any electrical modification either but it shouldn't be too tough I dont think.
http://www.d2moto.com/Items/lts103-a...Turn%20Signals
Old Apr 14, 2009 | 12:16 PM
divingindaytona's Avatar
Remember stock is BAD!
Wow that is a great deal! To bad I have LED's on the front and rear. I paid close to $50 for each pair.
Old Apr 14, 2009 | 01:35 PM
malahhaor's Avatar
malahhaor is on a distinguished road
too bad shipping according to their Shipping Calculator is over 11 bucks.
so 2 turn signals + shipping = $30+
Old Apr 14, 2009 | 02:14 PM
L8RGYZ's Avatar
That 30 bucks is for all 4 turn signals. Really pretty good price.
Old Apr 14, 2009 | 04:52 PM
I ordered 4 Motrax arrows yesturday. I didn't want the hassle of wiring all the load equalizers for led's. Mine were $41 shipped.
Old Apr 14, 2009 | 04:58 PM
finepooch's Avatar
i'm going through that resistor/led bs right now.
Old Apr 14, 2009 | 05:20 PM
malahhaor's Avatar
you are right, i did not realize it was for a pair.
So am i assuming correctly, these can be connected directly w/o resistors of any kind?
Old Apr 14, 2009 | 06:15 PM
finepooch's Avatar
the stalk seems kinda long
Old Apr 14, 2009 | 06:21 PM
finepooch's Avatar
the shipping to canada is noly $9.90. that's cheap.
Old Apr 14, 2009 | 09:38 PM
malahhaor's Avatar
Ordered a pair. used promo code of D2M2008 and got 15% off......
Old Apr 15, 2009 | 01:00 AM
finepooch's Avatar
can the stalk be shortened? maybe that rubber looking piece can be taken right out? what about resistors or flashers to fix the fast flash rate?
Old Apr 15, 2009 | 08:41 AM
hardened stihl
I dont know if we should assume that they dont need resistors. They probably do. I would put a multimeter on the once connected to the battery but before mounted and compare V and I to the stock ones.
Do the motrax ones require no electrical mods???
Old Apr 15, 2009 | 03:42 PM
None. They are two wire, so the fronts won't be running lights, only signals. I got 'em today. Me likes!
Old Apr 15, 2009 | 04:38 PM
finepooch's Avatar
i'd like to order a pair but i won't because i don't know if the stalk can be shortened.
Old Apr 15, 2009 | 05:02 PM
The LED ones always needs resistors, in some they are internal, but hey are there none the less..
The other option is to use a load independent flasher... It's both cheaper and easier than mucking about with 4 resistors...
Old Apr 15, 2009 | 05:15 PM
finepooch's Avatar
stupid hard to find resistors! i'm wondering about wiring the oem socket and bulb in the system and just shoving it in the trunk!
Old Apr 15, 2009 | 05:51 PM
The easy solution would be one of these... http://shop.ebay.com/items/?_nkw=led...flasher)+relay
Just replace the stock relay and you can use any combination of bulb and/or LED's...
Old May 5, 2009 | 12:29 PM
malahhaor's Avatar
So i installed these, they are about an inch longer than what i already had but way more visible when on, even in daylight. So for safety and functionality reasons i will keep them.
Will try and get pics as soon as i can.
Old May 5, 2009 | 06:55 PM
Circuit_Burner's Avatar
guru of things sparky
Im building some xeon strobe turn signals, updates and parts for the kit later...
ranchomice
Nov 17, 2010 07:53 AM
Anto
Sep 12, 2009 11:47 AM
Anto
May 5, 2009 05:20 PM
tbartley
Jan 16, 2009 09:31 PM
Shortlived99
Apr 24, 2008 06:57 PM
