Got a problem
Old Nov 16, 2013 | 10:41 PM
drewski's Avatar
semi-advanced novice
drewski is on a distinguished road
Got a problem
Jumped on the old girl today for what I was hoping would be the last ride of the year and she didn't respond well at all. She sounds normal at idle and in neutral but when I put her in 1st and tried to move out, she was bogging down real bad and shuddering, almost like I was in 2nd or 3rd. I can move through the gears fine with the clutch in but I can't get her going smooth. I didn't see if this went away once I was up to speed, didn't want to push it. Any ideas on what a possible issue might be? 1998 with 24K, about 2K since the last oil change and never a problem until now. She sat for about 3 weeks since the last ride and everything was normal then. Thanks in advance for any suggestions.
Old Nov 17, 2013 | 04:18 PM
sjscicluna's Avatar
bad fuel, mice in air box????
Old Nov 17, 2013 | 04:25 PM
Wicky's Avatar
Sounds like a leak in your petcock diaphragm .
Old Nov 17, 2013 | 04:26 PM
drewski's Avatar
checked the air box, was clean. Looked it over closer and noticed a fuel leak at the petcock. Another thread had somewhat similar symptoms and the suggestion was to check for a torn diaphragm at the petcock. I'll look into that in the spring and go from there. Time to put her away here anyway. Thanks though.
Old Nov 17, 2013 | 04:29 PM
Wicky's Avatar
Best empty your tank if you intend to lay the bike before repairing it up otherwise the fuel will all dribble out.
Old Nov 17, 2013 | 04:55 PM
drewski's Avatar
Ill drain it this week. She's going into storage next weekend. Thanks Wicky.
Old Nov 21, 2013 | 05:12 PM
bird-rider's Avatar
bird-rider is on a distinguished road
It could be a bad fuel or a dirty filter and fuel system. Have it thoroughly drained and cleaned. Another this is to replace your plugs.
nnjhawk02
May 2, 2014 05:04 AM
bostonhawk
Sep 1, 2012 08:45 AM
simone
Jul 15, 2011 11:13 AM
Yardstick
May 14, 2008 07:35 AM
moisesdtp
May 28, 2006 01:49 AM
