Is this gas cap on right?
Old 02-13-2016, 08:14 PM
thedeatons's Avatar
I didn't take a picture of this when i disassembled it, and now when i try and close it the cap won't seat right...
James
thedeatons is offline
Old 02-14-2016, 08:28 AM
Well take off, eh.
Jack Flash's Avatar
There's only one way to seat these in, you can't go wrong.
What do you mean by 'seat right', is it not sealing ? It fails to clip in place and reopens ?
If this is the case, have you done anything to the tank or cap itself (paint ?)
Jack Flash is offline
Old 02-14-2016, 08:37 AM
James, did you tighten the bolts with the cap open or closed?
VTR1000F is offline
Old 02-14-2016, 09:02 AM
thedeatons's Avatar
I can't get the cap to click into place. It gets to a certain place and then stops.
I took it apart for powdercoat, but only coated the outer ring and top cap.
I thought i put the mechanism back together right, with the 3 screws and that metal ring...
I tightened up the outer ring with the cap in the open (up) position.
James
Old 02-14-2016, 09:36 AM
Try loosening the outer ring and see if it will click closed, then tighten outer ring?
VTR1000F is offline
Old 02-14-2016, 09:38 AM
Try loosening the outer ring, see if the cap will click closed, then tighten outer ring?
VTR1000F is offline
Old 02-14-2016, 09:40 AM
Oops. If that doesn't work, try one more time. Third time's a charm.
VTR1000F is offline
Old 02-14-2016, 01:32 PM
thetophatflash's Avatar
++1
thetophatflash is offline
Old 02-14-2016, 01:38 PM
thedeatons's Avatar
No dice... I'm wondering if the metal ring got tweaked too much during reinstall under the rubber boot?
I'll have to check that out
James
Old 02-15-2016, 07:36 AM
Well take off, eh.
Jack Flash's Avatar
Was the top cap an all around inner/outer powder coat, or just the outer top part that you see when closed ?
If it's all around, inner/outer, their lies your issue. These are designed to be a snug fit with no room for error. If you add powder coat, you have changed the tolerance, and, you will need to address that. Either you sand it back down (not the best in my book) or remove powder coat (I recommend) and have the job done again.
Also, the outer ring includes the three legs where it screws to the tank. If there is powder coat at the base of the three legs where they sit on the tank, once again, you must remove the powder coat. The thickness of the powder coat rises the ring up just enough to prevent the cap from clipping into place.
Old 02-15-2016, 08:00 AM
thedeatons's Avatar
Thank you!
A similar idea came to me in the middle of the night. I already have the cap loose, so i'll remove it today and use acetone to remove the powdercoat on the bottom of the three posts... I'll try that first and see if it fixes it
James
Old 02-15-2016, 01:29 PM
thedeatons's Avatar
Praise JESUS! It's fixed! Torr it down and got lots of powdercoat off and also clean the threads out for those three screws.
Works perfectly now!
Thank you guys!!
James
nfbzike
06-07-2008 09:43 PM
infidel_mike
04-22-2008 06:32 PM
Radiaoktiv
02-06-2008 08:12 PM
Motophoria
05-19-2007 05:08 AM
Quick Reply: Is this gas cap on right?
