Fuel shut-off valve?
Old 10-21-2009, 10:43 PM
avramd's Avatar
avramd is on a distinguished road
Hello,
I'm the almost-proud new owner of an '03 SH996. I literally just got home with it, and I can't get it started. It turns over plenty, but isn't really firing.
Unfortunately I don't have the owner's manual, the previous owner couldn't find it. So, I do not know if this bike even has a fuel shut-off valve like a lot of older bikes or not. I looked around and couldn't see anything obvious anywhere.
Could someone please either tell me where it is or let me know that I'm looking for a ghost?
Thanks!
avramd is offline
Old 10-21-2009, 10:52 PM
Carnivore
Grizz's Avatar
Grizz is on a distinguished road
I think the fuel petcock is internally controlled my the engine vacuum but you may want to wait for someone more senior as I only bought my 03 last year.
Also, I know it's a stupid question but are you using the choke to start it? Remember, the hawk is not fuel injected, it wont start like most others. Up here in Canada mine won't start at all when the engine is cold w/o being choked first for at least 30-40 seconds.
Grizz is offline
Old 10-21-2009, 10:58 PM
RK1
RK1's Avatar
Service manual;
http://www.superhawk996.net/Honda_VT...ice_Manual.pdf
RK1 is offline
Old 10-21-2009, 11:00 PM
avramd's Avatar
Haha, not it's not a stupid question, and yes, I was giving it choke. I think it just has old gas in it since the previous owner hardly used it.
avramd is offline
Old 10-21-2009, 11:28 PM
avramd's Avatar
Originally Posted by RK1
whoa... awesome, thanks!
I don't suppose you have the user's guide too?
avramd is offline
Old 10-21-2009, 11:53 PM
Is the kill switch in the run position? Somebody had to ask.....
8541Hawk is offline
Old 10-22-2009, 12:45 AM
avramd's Avatar
yes yes, kill switch is "down" (towards me). Although why it allows the starter to turn when it's in the kill position in the first place is beyond me.
avramd is offline
Old 10-22-2009, 07:39 AM
rbrais's Avatar
The kill switch only stops the spark. The engine will still crank over. That's normal for a bike.
I believe there is a fuel shut-off on the underside of the tank. You have to unbolt it and tilt it up.
rbrais is offline
Old 10-22-2009, 08:07 AM
Carnivore
Grizz's Avatar
By the way, welcome to the forum!!
Grizz is offline
Old 10-22-2009, 08:39 AM
yruyur's Avatar
Welcome, and the fuel petcock is mounted to the bottom of the rear part of the tank. It is vacuum controlled so you don't have to turn it on, there is a manual shut off on it when you remove the tank. If you take the two tank bolts off front of the tank you can lift the tank to access the petcock. I would remove the fuel line to see if anything is comng out. There is a screen to catch stuff mounted to the petcock in the tank. If you remove any lines from the petcock make sure to put them back in the same place as that can cause what you are describing. I would try to narrow it down to fuel or electrical.
yruyur is offline
Old 10-22-2009, 08:42 AM
Boosted
Syclone's Avatar
Yes and no, the VTX's at least won't even crank when the kill switch is on.
Syclone is offline
milo2
03-30-2012 02:44 PM
98VTRrider
08-01-2010 07:12 PM
VTS
12-23-2009 07:58 AM
seb421
03-18-2009 04:54 AM
Quebecer
07-07-2005 06:21 AM
Quick Reply: Fuel shut-off valve?
