Fuel level sensor dead ...again!
Old May 11, 2010 | 07:24 PM
Dan Cronin's Avatar
For the second time I'm stuck with a fuel sensor that reports empty when the tank is full. I just get the dreaded flashing lower level bar.
I installed a new sensor unit last fall and all was well until I filled up last week. I must have bumped the sensor with the filler hose at the gas pump. Dam these things are flimsy.
I checked the connectors, they are tight and it doesn't seem to have tweaked the float arm.
IIRC, the sensor unit for a 2002 SH has a small flat bar wrapped with coils of thin wire. The float arm moves a wiper arm across to the bar to adjust the circuit resistance. Kind of like a potentiometer. (Going from memory here) I'm betting one of those small wires got busted again.
Has anyone ever soldered one of these things back together? I'm not looking forward to spending another $60 for a new one if it can be repaired.
Thanks in advance for the help.
Old Jun 24, 2010 | 04:29 PM
General Maximus's Avatar
General Maximus is on a distinguished road
Maybe thats what is wrong with mine. All along I thought it was a electrical problem. Maybe you could talk/type me through what I should be looking for. I dont know anyone around here that has one to go look in their gas tank.
Thanks for the help
Old Jun 24, 2010 | 06:02 PM
Syclone's Avatar
Boosted
If you are sticking the nozzle into the tank enough to hit the sensor, you're doing it wrong. That's about all the help I can be.
Old Jun 24, 2010 | 06:10 PM
residentg's Avatar
Originally Posted by Syclone
If you are sticking the nozzle into the tank enough to hit the sensor, you're doing it wrong...
I thought that was the whole idea.
Old Jun 24, 2010 | 06:28 PM
RWhisen's Avatar
Former Superchicken Owner
Make sure you check your ground, clean it up with a little sandpaper. Just a thought
Old Jun 24, 2010 | 07:23 PM
Maybe I am too much of a Newbie to be posting this. Hope it is not against the rules
Old Jun 24, 2010 | 07:34 PM
Syclone's Avatar
Boosted
Are you being serious or did I miss the sarcasm bus?
yruyur
Apr 30, 2009 08:30 PM
yruyur
Apr 17, 2009 11:05 PM
flyingeyepro
Apr 16, 2009 06:00 PM
clarkwebb
Jun 16, 2008 05:37 PM
flyingeyepro
May 20, 2008 11:44 AM
