front brake buzz
Old Aug 1, 2011 | 06:54 AM
ninjagoalie's Avatar
front brake buzz
Looking for help. My front brakes "buzz" when I apply them. Not REAL loud, but I can hear it lightly with my full face helmet on. Sounds like it is coming from the caliper, but not 100% sure. Doesn't seem to impact the brake operation at all. Only makes the noise while moving, and not much when going slow (under 15 mph). I put new pads on at the beginning of the season and bled the lines. I just noticed this noise about 3 days ago. I am going to take the calipers off for inspection, but was wondering if anyone has dealt with this sort of thing before? Thanks in advance.
Old Aug 1, 2011 | 07:26 AM
RickB's Avatar
Some buzz is normal, I have noticed it on a number of my bikes... I was told it has to do with the holes in the rotors but I can't say for sure.
Old Aug 1, 2011 | 08:00 AM
Old Yeller's Avatar
mine makes a little noise when applied too. you could try removing, cleaning, and checking everything just to be sure all is working fine. You are probably ok though.
Old Aug 1, 2011 | 08:49 AM
shake-n-bake's Avatar
Umm...I'm awesome. Duh...
shake-n-bake is on a distinguished road
mine sounds like a real faint cicada when i apply mine
Old Aug 1, 2011 | 09:53 AM
jay956's Avatar
ebc pads do it pretty loud too. its normal
Old Aug 1, 2011 | 10:05 AM
thanks for the responses. I feel a little better, but I am still going to take them apart and clean/inspect/etc to make sure all is well. I did put new EBC pads on this year.
Old Aug 1, 2011 | 10:54 AM
jay956's Avatar
trust me its fine, the ebc pads are loud. you can even hear it on my track videos, even over all the wind and engine noise.
Old Aug 1, 2011 | 11:58 AM
Old Yeller's Avatar
yeah, but you're probably running stock exhaust and going really slow though!
Old Aug 1, 2011 | 12:06 PM
jay956's Avatar
well its a f4i with a full tbr system, but i am slow... so... idk where that falls
Old Aug 2, 2011 | 11:08 AM
msethhunter's Avatar
It's normal. Brakes work by turning rotational energy into heat energy. Drilled rotors have a spot for air to get trapped with the heat build up. Most pads also expel a small amount of gasses when they heat up. When that hole opens up from the rotor moving past the hole, the heated and expanded air/gasses escape make a popping noise, but because you are traveling at a high rate of speed the popping noise sounds like a buzzing noise. If you had solid rotors, you wouldn't hear anything. This is also why under light braking, you don't hear much, but under heavy braking it get's much louder.
Old Aug 2, 2011 | 11:25 AM
EBC HH pads this = normal. Mine do it too. (OEM pads don't)
Old Aug 4, 2011 | 02:00 PM
klx678's Avatar
Just hangin' out
klx678 is on a distinguished road
First time I heard that kind of noise was on a used Suzuki 800 Marauder. It sounded kinda cool and funny. I know my Zephyr does it. No explanation, just know rotors with a bunch of holes tend to do it.
Kawasaki did some rotors with semi-random hole spacing to take it away, some companies I think use the slotting for the same reason. It might work since the KLX doesn't make any sort of cicada type noise with the pattern it has.
Old Aug 4, 2011 | 03:10 PM
I run EBC pads with ProLite rotors and a hard slow down from near a hundred (speed trap) they scream. It's like a jet engine powering down. My policy around rotors and calipers is keep everything around them clean but disassembling is likely to cause other problems.
Old Aug 5, 2011 | 05:24 AM
nekkid's Avatar
What he said...
Old Aug 5, 2011 | 07:52 AM
klx678's Avatar
Just hangin' out
Interesting...
Old Aug 5, 2011 | 10:27 AM
geekonamotorcycle's Avatar
I needed to ask this same question myself.
Old Aug 15, 2011 | 03:45 AM
Garbanzo's Avatar
Garbanzo is on a distinguished road
Brake noise
If it sounds like a fishing reel when the line is being spooled, nice catch. It's OK. Beware of grinding sounds - you could have some debris between the pad and rotor - or worn pads - check the rotors for grooving.
I never use my brakes though...
Aug 4, 2014 02:22 PM
VThokie412
Feb 1, 2012 10:48 AM
wtxrider
Jul 13, 2007 07:57 PM
EngineNoO9
Nov 25, 2006 08:15 PM
CNI Dawg
Nov 6, 2005 06:59 PM
