Do I need new sprockets and chain?
short answer, yes
When you are backed all the way out on the chain adjusters you should get a new chain. Chances are if you wore the chain out (and by the looks of it that was done a long time ago) your sprockets are probably on their way out. Worst case the chain breaks apart and takes a piece of your leg with it.
Also based on the look of the chain i would say it has not been waxed or oiled in a long long time. Doing this on the regular will increase chain life as well as giving you some piece of mind.
hmmmmm yes,that can be very dangerous,mine is in a little better condition,but mine isnt strecthed out as far as yours.the teeth do look worn and chain is kinked,it might be because theres to many links anyway,mine is stretched pretty bad but not to where its hitting pipes.but over all,you need new chain and sprockets bad.its 101 links in case youre wondering.i wouldnt ride until problem is fixed.too dangerous in my opinion.
I had over 41,000 miles on the original, and it was just on the edge of the "replace" indicator on the adjuster. But it was way overdue, many tight links. My rear sprocket wasn't as bad as yours though. I agree with what others have said, stop riding until you replace it.
ummmmmm yes,you do very badly,i really hope you joking because that is very very bad,thats death waiting around the corner.
Thanks for every one who replied. I am going to order a new set. I was looking and I found this site selling a chain and sprockets set
Better more expensive set
http://www.sprocketcenter.com/p/3703...00f-97-06.html
Cheaper set
http://www.sprocketcenter.com/p/3149...00f-97-06.html
What one should I go with they have the option to change the gear ratio
I was going to order the first one
http://www.sprocketcenter.com/c/1618...00f-97-06.html
Cheaper set
The cheaper set looks like the original equipment chain to me. Depends on whether you want to spend $40 to get a better than stock chain.
For the riding I do (I'm not wheelie happy) I like the stock gearing. But many others go lower.
The new chain will last longer if you clean it and lubricate it. It's worth investing in a rear stand to make these and other jobs easier. You can clean the chain with kerosene and a brush. Some people use toothbrushes with the bristles cut down. Others get a chain brush from a bike shop. There is a wide range of opinion about which chain lube is best. Do a search and take your pick. Having the proper amount of chain slack and keeping the wheels aligned also are important.
What would you recommended for for lubing the chain, I bought chain wax is this any good?
I recently switched to Motul Chain Lube: http://www.kneedraggers.com/product/...tul-Chain-Lube . It works well and dries quickly so it won't sling off and get all over your bike. It also doesn't attract dirt like some lubes do, because it's not sticky once it dries.
There are other lubes that work just as well, but this one was at my local shop. I'd avoid the sticky lubes. They lubricate well, but make a huge mess.
Dear Justinity,
Just about any chain lube from a motorcycle shop will do the job. Some need to be applied more frequently than others. Some stick to the chain better than others. Some attract dirt less than others.
Some people swear by WD-40. What you've got is fine.
Right now I'm using Dupont teflon multi-use lubricant. It comes in a spray can. I got it at Lowes. It's cheaper than most chain lubes.
I'm new to this, but I read or heard somewhere that using Kersosene leaves a little bit of a film, which is un-wanted. If I remember right, the guy said to just use a dry rag and wipe off the old grease really well then re-lube. Any effort to clean more than that causes more problems in prolonging the life of the chain than it does to help.... seemed reasonable when I heard it.
Well do my sprockets look ok, or should I get the set?
New chain on old sprockets wears a lot faster...you'll get better mileage out of your chain if you replace the lot.
Check out my beginners guide to doing the job if you want...
http://www.haymouth.co.uk/phpBB3/vie...p?f=31&t=16500
WD-40??? No!! Not even to clean a chain!! It forces any and all lube in the links out. Bad thing on O or X ring chains. Kerosene the same. I clean mine with light weight motor oil....oil to clean off oil. It works and will not damage your chain. Tons of rags and a brush too.
To lube....Scotoiler. 2nd to none!!!
520 conversion....will handle the HP of the hawk. Mine done LONG ago.
Fish
Fish
I clean chain and sprockets(gunk around edges of teeth) with a rag/brush and silicon spray. Chain wax and other chain lubes seem to attract dirt. After you clean chain, I lube with a little gear oil and wipe off well or teflon spray alterantely. Remove chain guard for ease of cleaning and aligning sprockets when adjusting chain.
520 conversion is awesome if you buy quality chain and sprockets and take a little care. I wouldn't skimp on this especially after I went through a vortex alum sprocket in 3000 miles(sum of all parts ebay junk). Never again. Drive is train too important.
okay i was wrong...there were 16 teeth left out of 45. i just went back to stock gearing and it feels like a brand new bike.
