clutch oil and bleeding
Old Jul 6, 2013 | 05:42 PM
sunshinehawk74's Avatar
sunshinehawk74 is on a distinguished road
Can the clutch be bleed without a mityvac? Can it be bleed with the pressure of the handle?What type of oil does the clutch use?
Old Jul 6, 2013 | 05:47 PM
KCCO's Avatar
Clutch uses DOT 4 just like the brakes. Yes you can bleed it without a vac system. It's no different than bleeding the brakes.
Old Jul 7, 2013 | 02:22 AM
Clutch doesn't use oil...
The clutch does NOT use oil... Fluid, please... DOT4...
Oil goes in the engine/gearbox, and the fluid goes in the brake and clutch system... Easily done without a mityvac or similar, just takes a little patience and time...
thedeatons
Mar 18, 2014 09:52 PM
Hawkrider
Aug 12, 2009 10:51 PM
marcvtr1000
Feb 24, 2009 12:48 PM
lynchie
Aug 20, 2008 07:53 PM
captainchaos
Jun 4, 2007 12:39 PM
