CCT survey
Yes, I've searched first (!).
Just wondered if anyone had done a survey to simply find out what years pose the biggest trend for CCT failures...or for that matter, what mileage? If you want to throw in your info, I'll build some data to show year / miles / OEM or APE and post this once I can see sufficient info that forms a trend. It sure would help in my decision making to go APE or not. Maybe it will help others... All I need is; 2000, OEM, 13,000 kms. Or whatever...let me know... |
I don't know that any certain years pose more threat than others, but I replaced my OEMs with Truck's manual ones last year, 1998 w/ 20k miles.
Have an '00 with stock CCTs... about 16,800 miles.
I do also have some APEs ready to install though when I do my (now overdue) valve inspection. This forum has made me paranoid! :) |
I don't think year of production has anything to do with it. My '03, which I bought new, developed front cylinder cam chain rattle before 5k miles. Without the rattle, I never would have worried about it. I spent a bit over $100 for APE's to make it go away.
If you've got the rattle, or you're just worrying about it, you'd be a fool not to spend a big, fat, friggin' $100-$120 and forget about it. |
2003, oem with almost 17000 miles.
1998 OEM, changed the first set out at 60k miles and replaced them with OEM units, now at 80K miles.....
Don't slam the throttle shut at high RPM or let it sit and idle on the side stand and the stock units will last for a while... |
1999, 36000kms, Stock CCT's but have a set of APE's in the mail and should be here any day, plan to change them out before the summer hits. From reading about the failures on the forum it seems like cheap insurance considering I want to keep this bike for alot of years to come.
1998, OEM, 27,000 mi ~ 43000 km
98' with almost 30k. Just did the APE swap on mine. The stockers were rattlin like a mofo. And yes after reading al about other members horrible CCT failures and having the top end having to be rebuilt after thet went on them, I got me a set. IMHO its the only way to go if you do alot of high RPM riding, twisties, etc.
Oh and When I did my swap I noticed that the valve train was alot quieter. Hope that heps others decide to spend the money on them. I paid 104.95 shipped. |
99, OEM, 18k miles.
98,replaced with oem at 35,000 miles. 65,500 on bike now.
I just replaced my stock CCTs yesterday with some APEs....it's a 1998 with about 28,000 miles...quite a noticeable difference in engine noise...I'll probably ride it more often now that I'm not worried about a breakdown and likely repair costs!
2005 - 9,600 miles. I am replacing my OEM CCTs with APEs now since I have everything apart to do the PAIR removal and TPS adjustment. I should look at the valves too, even though I have another 6,400 miles before that is due. JB
39000 miles stock cct's if helps chain was replaced in 37000 miles.
can i ask if the chain was replaced would the ccts have been checked as the normal procedure as i have had the bike since 37900 6mths???, sorry to side track... |
99, OEM, failed at 28,000
03, oem, 25634 miles
98' and changed CCT's at 34k. Had really bad chain rattle which made me park it for a few weeks till the Tuck's CCT's came in. Now runs smooth with not noise at all.
'99 still OEM 11,500 miles
I knew I saw this thread before:
https://www.superhawkforum.com/forum...ad.php?t=18699 |
Link me the truck's cct site
2001, OEM, 18k
Just hit 18k last week...engine is stock other than removing the smog crap. |
Originally Posted by NakedOne
(Post 258785)
Originally Posted by lazn
(Post 258759)
I read about the stock CCTs going out about 5k miles ago...when I hear the rattle...or decide I have some $ to spare...I'll upgrade to APEs. Until then....ride on and keep the rubber on the pavement! Two down!!! 8-)
the definitve CCT thread
https://www.superhawkforum.com/forum...ad.php?t=11275
BTW, on my fast red 98 50k mile major I put in the APEs |
Installed Trucker's CCT's on my '03 at 15k mi as preventive maintainance. No issues.
98 OEM 18K
98 OEM 20K Miles
A little over 4000 miles and I have the APEs sitting on my toolbox for installation once I get back from delivering an airplane to Afghanistan.
In my unofficial, purely guestimate, based solely on feeling, opinion. There is probably a less than 10% chance of your CCTs failing.
But, APE ccts are only a $110 investment and they prevent a $2000 rebuild. You buy insurance for the bike for more than that per year. |
