calipers: GSX-R vs RC51
Old Mar 15, 2008 | 01:50 PM
Hi folks,
I am currently running the MC and calipers from an RC51 (SP-2). I have a radial MC (16 mm) from a 2005 R1 on the way. Since I will be overhauling the brake system anyhow, I was wondering if it would be worthwhile to replace the RC 4-pot calipers with the 6-pots units from a 01-02 GSX-R 1000? Does anyone have any experience in the matter?
cheers
Old Mar 15, 2008 | 04:10 PM
hawxter996's Avatar
ole dirty bastard
keep the sp 2's.
according to Thorsten Durbahn,they are among the best for the money.
in case you are not aware of who he is ,google his name.
Old Mar 15, 2008 | 04:32 PM
Thumper's Avatar
I got the 6 Pots and an 05 GSXR 1000 Radial MC. Great setup!
As far as the Calipers I would look at the CBR F4I. I think others have done that setup as well, but research.
The 6 pots are pretty much a direct fit with just a little filing or dremmel tool.
I run Vesrah pads, but pretty much all the HH pads are great.
Old Mar 15, 2008 | 04:33 PM
Thumper's Avatar
Originally Posted by mikstr
Hi folks,
I have a radial MC (16 mm) from a 2005 R1 on the way. cheers
Hey i am curious if the R1 MC had a bleeder on the MC like the GSXR one i bought. Sure as heck made it easy to swap the crappy stock VTR one and bleed the lines.
Old Mar 15, 2008 | 06:54 PM
AZZKIKER's Avatar
I had both over the years. The RC 4 piston caliper mated to its rotor is superior to the gixxer 6 piston caliper with the superhawk rotor. but the gixxer setup is still way better that the stock. Master cylinder makes a big difference, so does the rotor diameter.
Old Mar 15, 2008 | 07:12 PM
I've had both the GSXR1000 6 pots and the F4i/RC51 calipers. Both work great, but the F4i calipers are cheaper,theres a greater variety of pads available and they are waaaay cheaper. In short... I ended up giving the 6 pots to a buddy of mine.
Old Mar 16, 2008 | 02:58 PM
thanks guys, I think I'll be sticking to the SP-2 calipers I now have, especially given that the HH pads I installed only have about 5000 miles on them (still a lot of life left in them).
cheers
Old Mar 21, 2008 | 07:30 AM
J.J.'s Avatar
J.J. is on a distinguished road
Which MC did you use with the f4i/rc51 calipers? Or do they both use the same one?
Old Mar 21, 2008 | 02:30 PM
I'm using the stock m/c on my '05 for the F4i calipers. I borrowed the m/c off of my old RC51 when I had the GSXR calipers.
Old Mar 21, 2008 | 08:39 PM
A pal that came home from Iraq recently installed the Rc51MC/Gixxer Caliper combo and was nearly busted out of his requalification excercises required for servicemen before they can ride their bikes. It's the Army's version of MSF.
The range officer's complaint: "you're doing stoppies with one finger."
Seems that he wanted all the fingers on the lever.
Spaz'
May 28, 2013 03:08 PM
speedkelly@aol.com
Apr 14, 2011 08:19 PM
autoteach
Mar 7, 2009 02:27 PM
Nanotech
Mar 1, 2007 03:17 PM
mamisano
Mar 26, 2005 04:08 PM
