Brake fluid leak?
Brake fluid leak?
So my bike has been sitting for about 2 weeks. I look near the front tire only to notice a small puddle. There is fluid on the lines but none above the splitter. I haven't taken a good look yet, but I thought I would throw this out there to see if there is a trouble spot that randomly starts leaking. Strange things is, it hasen't even been ridden in some time.
You might find that fluid could be weaping from the crimps (fittings-hose). That is a stress area on any brake hose even more so a hose with some age to it. Brake fluid tends to wick also, kinda moves in way you wouldn't think.
Funny thing is I just put new brake lines on my hawk. Call me the lucky one who's the fab-tech/sales rep. for Pirtek Midway St. Paul, MN. and we have a DOT brake hose machine. Made nice new SS lines for the bike in OE configuration (no dubble banjo).
Let me know if you need somethin Rancho. I'll be putting up some info on the rebuild of my bike as well as the brake/clutch lines.
So. . .did you stick your finger in it and sniff? Do a rub test?
I figured out that what I was looking at wasn't fluid from the bike's internals, but wash residue that dripped when I moved it from the swing arm stand to the side stand.
No, I didn't taste it. That test is reserved for other hobbies.
Wash it off and dry it. Then, after making sure your master cylinder is topped off, pump the lever and hold it several times. If it has a leak big enough to create a puddle, that should show you where it is.
I think I'm going to do springs and possibly valves if it requires removal. Should I not ride it until it's done? Maybe a trip to the bay area with parts is in order!
It sounds like it is leaking pretty bad. The first thing to do is either get a piece of 35mm film (yeah I know it's not easy to find anymore) or buy a product called a seal saver. The dirty bike guys use them.
What you do is insert it between the seal and the fork tube and run it around which will remove any dirt which may be trapped in there that can cause a leak.
Also while you are doing that check the fork tube itself for and deep scratches or grooves.
Then if it still leaks, after cleaning the seals out, and the tubes look good then it's time to install new seals.
8541, Good tip on cleaning the seal. I got some old rolls lying around, just found some use for them. My forks do not seem to be leaking, but it might be a good preventive measure. Learning something new all the time from you guys.
Letsrideinsc
Dec 15, 2010 06:21 AM
justinity
Sep 19, 2010 04:05 PM
HawkRider98
Sep 10, 2008 09:07 AM
seattlesucks
May 6, 2007 01:27 AM
