Bought to restore......I hope
Old Apr 24, 2017 | 08:18 PM
sabermammoth's Avatar
sabermammoth is on a distinguished road
So bought this non running and took a chance. Title said had 4k miles on it. Put the battery in and says has 6600. Fuel pump is not working but I am pretty sure it is a relay. Dumped a little gas down the injectors and crossed my fingers. It fired up on both cylinders . Ordered some relays off ebay and now will attempt to fix all the hackjob wiring.
[IMG][/IMG]
Old Apr 27, 2017 | 02:44 PM
Just thought I would post a bit of an update. My relays came in from ebay. Put x2 on and it fired right up. Original issue was no spark (bad relay) and fuel pump not priming(another relay). The real learning part is that the relay clicked and had continuity on the coil. But apparently the switch had a broken leg. So just because you hear a click doesn't mean that the relay is still good.
Oh and I took it up and down the road. The fuel injection seems soo much smoother then the Super hawks carbs.
Old May 16, 2017 | 02:46 PM
Anyone know if the headlight/turn signal switch will work from the super hawk on the rc51 sp2?
kardiac996
Sep 27, 2012 09:51 AM
Wolverine
Sep 14, 2011 08:29 AM
joshn569
May 30, 2007 10:01 AM
Ogre8472
Oct 31, 2006 09:05 PM
spacemonkey
Sep 15, 2005 06:38 PM
