black smoke on take off....
would like to hear some sugestions before i tear into my bike. every time i nail the throttle a very large plum of black smoke blows out both my mufflers. i never really worried about it but my buddies said it was very noticable the other nite. does anybody elses bike do this? should i try to lean this thing out a little? or should i not worry ?
Re: black smoke on take off....
You should take care of it since running it over rich will continually build carbon and reduce engine lifespan.
Guest
Posts: n/a
To pull the needles out, insert one to the diaphragm cover screws in to the end of the needle holder and pull, rocking it back and forth. It has an o-ring that holds it in the bore.
What sizes are your main jets? Does it continue to pour black smoke at higher RPMs, or just initially?
99Hawk, how did you end up with a 50 pilot ?!
42 or 43 is stock, if I recall.
rc996, it only puffs one quck shot of black smoke as i hit the throttle to wide open. i had a 78 trans am that was built for the strip that used to do that but that thing had a 900 quadrabog that was built for the strip. so the needles are just held in place by pressure fit? i thought i read somewhere you had to turn the holder to the left to release them, but since you guys take your carbs apart on what seems to be a daily basis, i thought i would ask....thanx
kickerfox
Jun 13, 2012 06:25 PM
finepooch
Aug 22, 2008 05:30 AM
kl98vtr
Jul 26, 2008 11:04 AM
BLAKCK HAWK
Jun 13, 2007 07:19 AM
vmoto
Oct 4, 2006 12:51 PM
