anyone heard from truckinduc ?
Old May 25, 2009 | 06:03 PM
  #31
LineArrayNut, you're local and I think you have his number. Can you call him for us?
Old May 25, 2009 | 06:18 PM
  #32
nath981's Avatar
Originally Posted by dshakes
No i didnt. But i have searched ,searched and searched some more and am pretty sure that im getting chain slap. I just dont want to take the chance of riding it and having a failure. Cant afford to fix that you know? Plus i want to change plugs, valve check, coolant flush,oil change, tps chech/adjust,synch carbs and whatever else ican while i have it all apart. Have any tips/input that might help? would be greatly appreciated.
good. you can remove the bolt from the tip of each CCT and replace it with a longer one with a locknut to hold it in place. I've done it to mine 6 mos ago and it's easy as ****, costs nada. takes 20 minutes for both. I posted the directions somewhere on here but I'll have to look for it. get back to you. If you don't feel comfortable with it you can replace when you get them, but in the meantime, ride your *** off.
Old May 25, 2009 | 06:38 PM
  #33
nath981's Avatar
Originally Posted by Veefer97 (SBN)
Try this instead of buying a new CCT
Honda Cam Chain Tensioners, yes they suck big time but there is a $1.50 fix for the later Hondas, F3 and up. If the CCT has a plug (bolt) at the outer end remove it. Buy a 6X1.00X30mm bolt and nut. Thread the nut on the bolt and install the bolt into the hole that the plug was in. Gently (fingertip pressure only) rotate bolt until it makes contact with the piston. Hold bolt with wrench and tighten locknut against the CCT case. Your CCT will now be silent. Why does this fix work? The CCT in the Hondas does not have a ratcheting mechanism. It depends on a left handed threaded shaft that is spring loaded. Due to the locking pitch thread design this shaft cannot back up. Sounds good so far. Unfortunatly the shaft stays in one place so long that the constant vibration wears out the shaft or the nut that the shaft rides in. The shaft gets sloppy and does not exert enough pressure on the chain pad so the chain starts to rattle at high rpm. The bolt fix exerts just enough pressure on the threaded shaft that it prevents the shaft from vibrating and backing up thus eliminating the chain noise. Yes you will have to adjust the bolt eventually but so far I have no historical data as to how long the time intervals are in between adjustments. Maybe some of you big milege people can provide the data. Any way, hope it prevents you from buying a new CCT. Latest data, the cheap fix has been working for at least 60K miles in a Honda F4
note: my rear CCT leaked a couple drops of oil since it's facing downward so I put a small amount of gasket sealant made by loctite and it stopped. Also I used the little flat washers that you remove with the bolt. you don't have to worry about what position the pistons/timing are in or anything other than what it tells you above.
Old May 25, 2009 | 11:47 PM
  #34
LineArrayNut's Avatar
I could ride in
Yes, I'll call again Tuesday morn.
still just going to voicemail.
did mention again that y'all would appreciate some communication.
Old May 25, 2009 | 11:49 PM
  #35
I could ride in
How many miles on your bike?
Just curious...
Old May 26, 2009 | 10:20 AM
  #36
dshakes's Avatar
dshakes is on a distinguished road
miles
Just curious...
Just turned 9000.
Old May 26, 2009 | 10:37 AM
  #37
Just turned 9000.
Well if you are having CCT troubles at that point, has the bike been sitting unused? abused (wheelies and such)?
To me it seems a bit early, how long since the last oil change?
Old May 26, 2009 | 11:14 AM
  #38
dshakes's Avatar
Oil changed around 6500. My riding is about 50-50. Commuting to work during the week, weekend blasts with my buddys. It hasnt been unused but i am only riding local around my small city because im afraid of catastrophe.Paid truck for ccts but he seems to be on hiatus or whatever sooo... just trying keep my bike healthy you know? Iwas going to change everything and do a major tune up session when i received my ccts but im kinda stuck now. anyone know if the bolt quick fix described above works on a 2000 hawk?
Old May 26, 2009 | 11:26 AM
  #39
RK1's Avatar
RK1
FWIW;
I think it a waste of time trying to nail down the hows and whys of the CCTs.
My front cylinder starting rattling at 5k miles without ever having gone over 2k miles without an oil and filter change.
When I pulled the front CCT thousands of miles later there was a nice sheen of oil on the shaft.
Could that front chain have kept rattling away for tens of thousands of miles without jumping the sprockets? I wasn't willing to find out. Getting rid of the damn noise alone made me glad I replaced it.
Old May 26, 2009 | 11:33 AM
  #40
nath981's Avatar
hell yea! what do have to lose. 2 bolts, 2 nuts and twenty minutes. just make sure to finger tighten bolt. quit f*#kin around.
Old May 26, 2009 | 12:07 PM
  #41
dshakes's Avatar
Nuff said. be back in an a few hours to report progress.
Old May 26, 2009 | 01:18 PM
  #42
hawxter996's Avatar
ole dirty bastard
his last post was saturday on the other site.
Old May 26, 2009 | 01:49 PM
  #43
k-d-williams's Avatar
Originally Posted by nuhawk
Yeah, just a flat tire in life. I think he will be fine. I'd hate to have to drive all the way up there to beat him up over a fork brace.
well, you might be too late with the *** whopin cause he was last seen on his streetfighter, his tank bag full of greenbacks, headin for the southern border with a great big ****-eatin grin on his puss. sorry fools!
Originally Posted by RK1
Ha! Ha!. A few thousand $ collected for CCTs and fork braces goes a long way in old Mexico! And surgery is like 20 cents on the dollar compared to USA!
Somebody said he's too busy on a streetfighter site to post here. I don't think folks are jealous about where he's posting, they just want a heads up on when they'll get the part they already paid for.
I don't know him from a hole in the wall. Lots of folks think he's straight up and I'll take their word for it.
Maybe it's 'cause I'm not twenty years old anymore, but if folks wanted to know what's up with the part they paid me for 3 weeks ago, I'd take 30 seconds to answer them.
I'm just going to be a little more patient before i start seeking some action. I can always jumpseat free of charge when the time comes. I would just like a response to my email and let me know when they are going to ship!
Old May 26, 2009 | 02:09 PM
  #44
RK1's Avatar
RK1
k-d;
The first part of my post you quoted was for fun, goofing on what others said.
The last sentence was serious. Anybody running their own business (like me, for instance) will tell you the most important thing from both a personal integrity stand point as well as a business stand point?
You respond to the problems/questions of your clients and customers as soon as humanly possible.
Old May 26, 2009 | 02:29 PM
  #45
k-d;
Agread, thats why i waited awhile before i delt with him. Seemed to be doing ok, so i made a deal with him and then all of a sudden i cant get a hold of him like the others. I own a aircraft business on the side and my customers always come first or they probably would not come back no matter how good i am!
Old May 26, 2009 | 04:42 PM
  #46
swordfish's Avatar
lets remember this guy isn't exactly a seasoned veteran. he's young. the young are erratic. they don't know those unspoken business policies. there are those on the forum who know him. I'm relying on their opinion. if they say he's straight, then that's good enough for now. I want to order a forkbrace too. but if the kid is having problems, then I can wait a little longer.
Old May 26, 2009 | 04:59 PM
  #47
Circuit_Burner's Avatar
guru of things sparky
Especially when a young guy gets hurt, all hell breaks loose in their lives as far as time and resources go. I hope hes doing ok.
Old May 26, 2009 | 05:35 PM
  #48
killer5280's Avatar
Hopefully he's busy cranking out the product he has orders for, or he's having his knee worked on. He really should post on here and let everyone know what's up.
Old May 26, 2009 | 05:40 PM
  #49
CentralCoaster's Avatar
It'll take him even longer to process the orders now that he's gotta write up a few pages of excuses for everyone.
Old May 26, 2009 | 05:41 PM
  #50
I could ride in
OK guys, I finally got a hold of him tonite. He's still very immobile and just getting his comp problems worked out. I made it very clear what he needed to do.
Old May 26, 2009 | 07:31 PM
  #51
dshakes's Avatar
L.A.N.
Thanks for the heads up and for looking out for the rest of us.
Old May 26, 2009 | 07:38 PM
  #52
dshakes's Avatar
nath981,
Finished the bolt swap on the end of the tensioner but its too late to fire up the hawk and let it idle. Will test tomorrow. also, in my crusade to make sure i got the lock nut tight enough i caved in the washer that was on the original bolt slightly. is this going to be a problem? I tightened the bolt with my fingers until it stopped and thats it. I put just a tiny bit of finger pressure on it at that point but nothing much at all. Will report tomorrow.
Old May 26, 2009 | 07:57 PM
  #53
jbaxx's Avatar
Honducati
Just sent Trucker an email regarding the status of my order on April 1. He told me about a month ago that my CCT's were "almost" ready to ship out. Let's hope He makes everything right.
Old May 26, 2009 | 08:01 PM
  #54
john3012's Avatar
Squided
Chill
Thats all good and great but i have a hawk in the garage that is sitting silent cause it has the death rattle!!! I NEED MY CCTS TRUCK!!!!
What is the rush? I will assume you are in Tampa (go bucks, whaoooh...). It seems like it has been raining every flipping weekend for four months up here in GA. I know what you mean, but remain patient my friend for the CCTs and sunshine will soon be upon us. Please, anyone listening?
Old May 26, 2009 | 08:04 PM
  #55
nath981's Avatar
nath981,
pretty easy huh? Supposedly, if you tighten the bolt too much it will sing or whine in which case you can back it off slightly, but if you fingered it and the bolt didn't turn when you tightened the locknut, you should be cool. Won't hurt the washer, but you probably don't need to torque it down too much. If you haven't yet developed a feel for how much to tighten what, you should either use a torque wrench or err on the side of caution by going a bit easier and putting on a dab of thread locktite. Did you put some sealant gasket on the rear CCT?
like I said, it's worth a shot for the little bit of time and effort to discover if that's your problem or if you must look elsewhere. should be fine.
Old May 26, 2009 | 08:24 PM
  #56
cmcconkey's Avatar
CMCC
cmcconkey is on a distinguished road
thank you LineArrayNut .
Old May 26, 2009 | 09:05 PM
  #57
Life is bitch, you got blown out knee, you got screaming sisters and aunts, and then there's those guys - oh **** again! All you got to do is let us know what is going on. Your product is rockin! Work your way through it. We're here, we will be here at the end - we just won't send you any more more money!
Morse code is not required. Pounding on your keyboard will prob not make it through either. In today's world you have to type. If not, the master communicators will prob show up at your door - pound a pipe up your *** and beat on your back until somebody answers back.
Old May 27, 2009 | 04:59 AM
  #58
hawxter996's Avatar
ole dirty bastard
he posted yesterday on the other site...........lucy! you have some splaining to do!!
if he can post there,he can post here.
if i sent money id be a little more than pissed by now!
Old May 27, 2009 | 05:40 AM
  #59
dshakes's Avatar
Wrong bucks! Go buckeyes!! It has been sunny and 85 here for a couple weeks now(few spots of rain) and its killing me! But im getting it taken care of.
Old May 27, 2009 | 08:36 AM
  #60
mboe794's Avatar
To be honest I've become slightly irritated. He cashed my check about a month ago. Since then I haven't seen any communication of any kind and still no brace. By the sounds of it he's got a lot on his table and I guess he really is trying do do a lot of us a favor. But one lousy post to explain how things are going would make all the difference in the world.
