99 superhawk please help
Old Mar 21, 2010 | 05:14 PM
ls503king333's Avatar
FNG!
ls503king333 is on a distinguished road
Angry 99 superhawk please help
i just bought a 99 superhawk with 19,xxx miles well taken care of. i put about 200 miles on it when all of a sudden it started losing power so i rolled the throddle on a little bit more it kept losing power until it died so i pulled the clutch and down shiftted the tire locked up i instanley pulled it agian and corrected myself i coasted down the hill to the next town about a mile but now the bike has no electrical at all i tried to hook my battery charger to the battery and jump it but it wont work are there any relays or fuses that should check? any thing will help the manuel wont be here for week so please help. i already checked the fusses under the seat none were out??
Old Mar 21, 2010 | 05:27 PM
NAVY8TR's Avatar
you have gas in the tank? sounds like you ran out of fuel to me.
Old Mar 21, 2010 | 06:58 PM
BeerHunter's Avatar
Slacker
Exclamation Regulator/Rectifier FAILURE
Most likely your regulator died and blew the main fuse. Follow the Batt + cable to the starter relay. That is where you will find the green 30 amp main (left side outer sub-frame). I suggest you do not try to run it again with the same regulator installed, else you will possibly cause other parts of the electrical system to burn as well as popping the new fuse. If you need to ride the bike a few miles to get it somewhere safe, you could unplug the regulator (right side outer sub-frame, 5 wire connector) and then replace the main fuse. The engine electrical system will run directly on battery power since the alternator will be taken out of the circuit by unplugging the regulator. You could also unplug to headlight to conserve battery power if needed, assuming you will be running daytime.
chadnol10
Mar 22, 2011 12:56 PM
ls503king333
Mar 26, 2010 07:57 AM
mcadena89
Jun 3, 2009 12:04 AM
hollywood13185
Apr 20, 2009 09:16 PM
mattvdsande
Mar 16, 2009 11:12 AM
