6-pot brake install
Old May 24, 2006 | 04:52 PM
EngineNoO9's Avatar
6-pot brake install
aight so I got the brakes from superbling today and just got done installing them and bleeding them with my vacuum pump. Went out to try them and.... nothing... they work 100x worse then my others.... so... I guess that means probably air in the lines??? that's all I can kind've think of...
Old May 24, 2006 | 05:42 PM
superhawk22's Avatar
Did you do the master and the calipers? Try starting at the master, lossen the bolt just enough to get fluid out when you squeeze the lever. Squeeze the lever till it bottoms very slowly, keeping it down close the bolt. Release and repeat until you have feel, then move to the caliper furthest from the master. Get all air out and move to the other one and do the same. I usually do it by hand give it three slow pumps and open the bleeder and repeat. It's always safe to bleed to much to make sure it's all out just don't let the res. empty. Hope this helps, good luck.
Old May 24, 2006 | 05:59 PM
EngineNoO9's Avatar
it has feel. it's just not grabbing very well it seems... I'll try again tomorrow...
Old May 24, 2006 | 06:25 PM
That's strange, is the lever mushy or hard when braking? Are the pads new, did you get any thing on the pads or rotors? They should stop great.
Old May 24, 2006 | 06:42 PM
superbling's Avatar
Yeah, is the lever mushy or firm?
My first thought is air still in the lines; especially since you had to start from scratch. Try a "check for bubbles" bleed without the pump. I find pumps are great for moving large amounts of fluid and sometimes air too.
Two other things, lock the brake lever down with a ziptie or similar overnight with the bars turned to the left. That can get the last bubbles out to. Also, maybe try the other pads to eliminate that possiblity. OK, here's a third thing; the copper crush washers might need replacing if it gets better but re-occurs.
Old May 24, 2006 | 07:20 PM
EngineNoO9's Avatar
well marmalade said if brake fluid got on them then I can kiss them goodbye... and brake fluid got everywhere. I cleaned everything up when I first got the package. I have these galfers that superbling sent too but I'm not sure they were safe either
Old May 24, 2006 | 08:45 PM
That's why I asked if you got anything on them, if they were soaked, throw'em away. For the price of pads it's not worth it unless they didn't get anything on them (the Galfers).
Old May 24, 2006 | 08:47 PM
EngineNoO9's Avatar
the galfers had stuff on them. the paint on the rear of the pads just rubbed off... I think I might need new pads
Old May 24, 2006 | 08:49 PM
Better safe then sorry, cheap compared to a crash.
Old May 24, 2006 | 08:52 PM
marmaladedad's Avatar
Hmm?
You can clean the rotors of any brake fluid. But the pads will sop it right up.
Let me know if you're disappointed in them. I'll take 'em off your hands.
Old May 24, 2006 | 08:53 PM
EngineNoO9's Avatar
Once they're working properly I'll love them. I thinkt he pads do need to be replaced. Just didn't seem to want to grab
Old May 24, 2006 | 08:56 PM
Yeah once a pad soaks that up there pretty much junk.
Old May 24, 2006 | 08:58 PM
Hmm?
Ooops. I had meant his whole caliper and MC assembly...
You got me. I have a fetish for old brake pads.
Old May 24, 2006 | 09:00 PM
EngineNoO9's Avatar
nah I understood. I'll send you the pads though :P
Old May 24, 2006 | 09:01 PM
Hmm?
Doh!! I love pads. Pads pads pads.
Pearl applicator?
Old May 24, 2006 | 09:15 PM
Sorry I guess I should've split that up, I was laughing at your eagerness and reinforcing the thought about the pads.
Old May 25, 2006 | 12:00 PM
Speed_Demon's Avatar
What are you running for a master cylinder. Your stock hawk MC might not push as much fluid as the 6 potters need. I would suggest you run the matching MC.
Old May 25, 2006 | 12:07 PM
Good suggestion but I ran mine with the superhawk master before and it stopped great. Oh and I'm pretty sure he bought the whole thing, master and calipers.
Old May 25, 2006 | 12:52 PM
EngineNoO9's Avatar
I'm using the MC that superbling sent me. it's not the stock one. I spent the last couple hours checking things and completely rebleeding the system and still same results as yesterday.. I'm so ******* frustrated right now. The handle feels mushy where before with the old brakes it'd hit the rotor and I could feel it grab real hard... I don't think the pads on the calipers were ruined btw. I could be wrong though...
Old May 25, 2006 | 12:54 PM
EngineNoO9's Avatar
anyone in SW virginia wanna come by and help? I'm so frustrated.
Old May 25, 2006 | 01:14 PM
EngineNoO9's Avatar
one issue I'm having and not sure if it's contributing to all of this is I had to seperate the pads some to get them to fit on the rotors. So seating them again so they'll be the perfect distance to grab is beyond me, I just pumped the brakes slowly till it grabs *shrug* I really have no clue how to do that
Old May 26, 2006 | 06:43 PM
3D02's Avatar
Because I'm a cheap bast'ad, I use a large syringe from a feedstore with a small piece of hose to "bleed" the brakes/clutch. Leave some room in the reservoir and inject fluid in from the fitting. Has always worked for me.
Karl
Old May 27, 2006 | 02:18 PM
EngineNoO9's Avatar
well I'm pretty sure it was the pads ******* me over. I put on the galfers which had fluid on them too but they stopped better then the ones on the calipers. so I ordered new pads and hopefully once those are on it'll stop even better
Old May 27, 2006 | 04:05 PM
That's what I was thinking since you said it wasn't grabbing.
Old May 28, 2006 | 09:05 PM
denmah's Avatar
denmah
just admit you screwed it up and youll never have a hawk better than mine
:-0 !!!
Old May 28, 2006 | 09:09 PM
EngineNoO9's Avatar
oh low blow
Old May 31, 2006 | 06:49 PM
EngineNoO9's Avatar
the new ebc HH pads got thrown on today and I noticed an immediate improvement once I felt the pads themselves cause they felt grainy and not a greasy type feeling that the others had. got the fronts on and rears. should be awesome once they're completely bedded in
Old May 31, 2006 | 07:43 PM
Hmm?
Bed-in? What's that? Just pull HARD. Insta-stoppie.
Old Jun 1, 2006 | 09:28 AM
EngineNoO9's Avatar
they say 250 miles till they're bed in... *shrugs*.
inderocker
Mar 25, 2010 10:32 AM
inderocker
Dec 19, 2009 03:38 PM
Just_Nick
Nov 3, 2009 07:42 PM
spEEdfrEEk
Jun 25, 2004 01:23 PM
