520 Chain 15/43 Baffles the Dealership.
Old Jul 20, 2011 | 07:11 PM
b1m3x8's Avatar
b1m3x8 is on a distinguished road
So I take my bike in to the Honda Shop to get a new chain and sprockets (520 - 15/43 already purchased online) and the guy at the service counter is looking at me like I'm an two headed alien. He starts off by saying why didn't you go 16-44 if you wanted to get more acceleration, and that they are practically the same? I have no clue if JT even makes a 44 tooth rear sprocket for 520 chains. If you are the customer shouldn't the shop just do the work without putting in their two cents in? They are not the one riding the bike anyway!
Old Jul 20, 2011 | 07:42 PM
autoteach's Avatar
Why didnt you do a 15/44?
Old Jul 20, 2011 | 10:00 PM
I won't even touch this one..... as my opinion on gearing should be pretty well known by now......
Old Jul 21, 2011 | 12:39 AM
RIPI's Avatar
RIPI
RIPI is on a distinguished road
Come on, why not do it again just for fun? In my opinion with the torque at hand being abused properly; sticking with a 530 chain, nice quiet, dampened oem front and a couple teeth up in the back makes the most practical set-up for the street. First gear is still fun and useable and the chain holds up a whole bunch better while the wheel base gets shortened a tad. Is the weight reduction of a 520 really worth the more frequent chain adjustments and accelerated uneven streatching? Unless you want to gear down to the point of eliminating those pesky "through neutral" shifts on one wheel, which might be fun to try for a day or two, two teeth up in the back and stock dampened front works.....I have tried both...can someone argue as to the 520 weight reduction benefit?
Old Jul 21, 2011 | 02:15 AM
Stephan's Avatar
RIPI: weight reduction on chain is about 400g, on rear sprocket about 100-200g (steel-steel) or 1 kg (steel-alu). Total 0.5-1.5 kg on rotating parts is not bad, quite cheap and simple mod to improve bike dynamics.
I run 16-43 as well.
Old Jul 21, 2011 | 06:36 AM
b1m3x8's Avatar
8541 I have read your opinion on the gearing, and almost kept my front at a 16 because of your posts. This post wasn't really to discuss gearing it was more about what opinions the dealer should and shouldn't give.
Old Jul 21, 2011 | 09:42 AM
man you should have gone 2/99 to get some real acceleration. :P
Don't worry about it, it's your bike, not his.
Old Jul 21, 2011 | 10:05 AM
b1m3x8's Avatar
A 2 tooth sprocket, lol. If I took my bike to the Triumph dealer they would of did the work, possibly gave me a high five, and sent me on my way no matter what size sprockets I chose. HAHA.
Old Jul 21, 2011 | 10:32 AM
Old Yeller's Avatar
I think 4 is the minimum number of front teeth you can use. Unless you are from West Virginia, of course. Then 1 is acceptable. After all, they invented the TOOTHbrush, not the TEETHbrush.
Old Jul 21, 2011 | 11:51 AM
AK Ronin's Avatar
907 Noble
There's something in the water at the Honda Dealership up here too. I just put my 16/43 sprockets on and did the 520 chain conversion. The chain came in with 120 links, and I needed the extras taken off, but I don't have a chain breaker and I didn't want to screw anything up by taking a concrete grinder to it, so I just took it down to the Honda shop. 3 Different Times. Each Time they denied me service. They wanted me to bring my bike in and "Look at it first" then "work on it". All I need is the chain cut right here though. "Well, with the bike here we'll have to charge $120 an hour for analyzing, not including the work that we would have to do, plus a minimum of $80 a day "garage fee".
I took the chain to the kawasaki shop yesterday. They did it perfectly in less than 5 minutes and they charged me $5. I couldn't believe it.
That marked the last time I ever go to the Honda shop. Suprisingly enough, my other experieces were worse.
Old Jul 21, 2011 | 11:58 AM
Old Yeller's Avatar
cheaper to just go buy a dremel tool to cut it. that's what I use.
Old Jul 23, 2011 | 04:23 AM
sapper7979's Avatar
sapper7979 is on a distinguished road
I dropped a tooth in the front and its the best thing i did. its not to much or to little..
Old Jul 26, 2011 | 06:03 PM
Jeepingoose's Avatar
Jeepingoose is on a distinguished road
So Im guessing we have to get chains cut to fit our bikes? I cant seem to find a 102 link chain anywhere...
Old Jul 26, 2011 | 06:32 PM
b1m3x8's Avatar
Motorcycle superstore should have them by links.
Old Jul 26, 2011 | 08:07 PM
CrankenFine's Avatar
LOL!!
Old Jul 26, 2011 | 10:52 PM
Yes it is normal to get a longer chain and cut it down. So you get the closet you can, which normally is 110 links and cut it to fit.
If you want, you can bring it by sometime and I can show you how to do it...
Old Aug 1, 2011 | 02:17 AM
Perfect, since I need a new chain ASAP before I ride much anymore.
Mike, you need any parts? Im looking to off load my parts bike.
smk2mch87
Apr 21, 2011 07:39 PM
Woody42181
Jan 13, 2011 08:07 AM
Shmittay
Jun 27, 2009 09:47 PM
justscoutin
Apr 12, 2009 06:48 AM
Speed_Demon
Dec 6, 2006 12:26 PM
