12V Plug Wiring
Old Apr 15, 2010 | 01:32 PM
reaper's Avatar
12V Plug Wiring
Has anyone wired a 12V plug to run a GPS unit off it? If so, which wires connect to the plug?
Old Apr 15, 2010 | 01:50 PM
peterpanic's Avatar
pragmatic anarchist
Should be 12 volts at numerous points on the bike. GPS won't draw like heated gear. I'd be tempted to tap one of the running light wires as they are conveniently up front. Third eye wiring could be used and just leave the silly thing unplugged. If you need power with the switch off just go to the battery (in line fuse real close) or the fusebox. IMHO the gauge cluster should have a lighter socket as well as speakers and a 1/4 aux for an ipod. No DVD tho, I ain't stupid.
Old Apr 15, 2010 | 01:51 PM
bracket mtd cig lighter receptacle attached to rt fork so it pivots with gps stem mount, fused to aux panel near batt. ziplock hd frzr bags for recept & nuvi 765t
Old Apr 15, 2010 | 01:53 PM
peterpanic's Avatar
pragmatic anarchist
Sorry. To actually answer your question... one positive and one negative (ground). On a lighter socket I believe the body is grounded and the center connector is hot.
Old Apr 15, 2010 | 04:31 PM
j shizzy wizzy's Avatar
mildly retarded
http://www.powerletproducts.com/products
go here first.
Old Apr 15, 2010 | 04:53 PM
reaper's Avatar
Perfect, thanks.
Old Apr 15, 2010 | 05:05 PM
alwayshonda's Avatar
alwayshonda is on a distinguished road
If you have a permanent connector for a battery charger wired in, you could use one of these connectors. $4 at harbor freight.
Old Apr 15, 2010 | 05:44 PM
shayne's Avatar
My tip for a GPS is to go against normal convention and power it from an unswitched power source. That way your GPS does not switch off every time you turn off the key. This prevents the unit from having to power up again and find satellites etc every time you stop.
Old Apr 15, 2010 | 05:45 PM
sparkyharley's Avatar
sparkyharley is on a distinguished road
lighter added
This is how I power my GPS. Zip ties hold it to the fairing stay. Powered directly to battery, yep I should have a fuse in there.
SWP
Old Apr 17, 2010 | 05:22 AM
reaper's Avatar
Would a 15A inline fuse be sufficient?
Old Apr 17, 2010 | 08:40 AM
Gregw's Avatar
15A would be way more than you'd need for the GPS (though it won't harm anything). My Garmin uses 10 watts, which is less than one amp. 5A would be a good size unless you're using it as a lighter too.
Old Apr 17, 2010 | 10:22 AM
If you want to protect a sensitive circuit or device, rule of thumb is 25~50% higher than than peak load except for motors (depends if it has a magnetic starter). In most cases 100% safety factor is applied. So with a draw of 1 amp, a 2 amp fuse is sufficient, though a 3 amp more common.
98ILVTR
Jul 23, 2011 09:38 AM
handkaudio
Dec 30, 2009 05:39 PM
Texassuperhawk
Apr 7, 2007 03:26 PM
ATLSHawk98
Dec 21, 2006 09:32 AM
thirty_ought_six
Aug 20, 2006 08:40 PM
