Foamy Oil Suzuki DR350
Hey guys, picked up a little winter toy a month or so ago and need some opinions. When I first got the bike, the oil looked good and clean, but as I rode it more and more, some white foam started to build up underneath the oil cap. Now i know that weather conditions and ride length can make this happen, but after a 1.5 hour ride today, there was still a lot of foam under the cap. The weather was 35 degrees F and 80% humidity. Changed the oil after the ride tonight and going to see if that will help, but would this concern any of you guys? Or is this weather related.
btw, it's an air cooled engine and dry sump oil config.
Xeris is correct, the oil in it was old built up moisture (and probably some acids to) I have seen this many times and while air-cooled engines are less prone to it, many short trips, especially in cool weather can really beat up oil. Also using oil not JASO rated for motorcycle engines can cause issues.
inderocker
Sep 29, 2005 09:41 PM
