Penske Shock
Old May 27, 2008 | 07:58 PM
Blue Ridge Boy's Avatar
Penske Shock
http://cgi.ebay.com/ebaymotors/ws/eB...m=190225485571
......Yeah......I'm bidding.
Old May 27, 2008 | 08:06 PM
joshuatest's Avatar
OUCH... MY A$$ HURTS!!!
Ummm... yea.. I want it...
Old May 27, 2008 | 08:09 PM
go away joshua...you already have your turbo.
Old May 27, 2008 | 08:25 PM
joshuatest's Avatar
Thats why I need a new Shock... That turbo of mine is kicking the stock shock's ***....
Old May 27, 2008 | 10:01 PM
sassage's Avatar
dude, shut up...I'm already in the bidding process
nothing can be a secret around this place
Old May 27, 2008 | 10:30 PM
KindredGhost's Avatar
KindredGhost
KindredGhost is on a distinguished road
I just bid 1 MILLION dollars. It's MINE!!!
KG
(JK btw... yeah, i want it...)
Old May 27, 2008 | 10:36 PM
taskmasta's Avatar
Pew Pew...lasers
sorry if i outbid you.
Old May 27, 2008 | 10:39 PM
sassage's Avatar
are you really sorry?
Old May 27, 2008 | 11:00 PM
taskmasta's Avatar
Pew Pew...lasers
no not really...but there is still alot of time left. lol
Old May 27, 2008 | 11:12 PM
sassage's Avatar
there we go...a little honesty
in the interest of being a good sport: I asked the seller a few questions and he said 15,000 miles & set up for 190 lb rider
Old Jun 5, 2008 | 08:57 AM
trinc's Avatar
damn... $440.00 for a shock with 15k on it ( needing a rebuild ).
amazing.
tim
Old Jun 5, 2008 | 09:11 AM
sassage's Avatar
amazing.
tim
no doubt...I dropped out fairly early in the bidding. did somebody here get it?
Old Jun 5, 2008 | 09:20 AM
superbling's Avatar
Yeah, a forum member got it. It's ironic that riders balk at paying for suspension (I was one) but happily fork over big bucks for hollow steel tubes with some fiberglass stuff in the end.
My wilbers shock calls for a rebuild between 20-30K miles at $90-125 service charge.
Old Jun 5, 2008 | 09:28 AM
sassage's Avatar
I'll spring for some better suspension (too big a guy to stick with stock) when the money's right. just looking for lower miles if i'm gonna buy used. picky, picky i know
haven't heard much about wilbers, good stuff?
Old Jun 5, 2008 | 09:37 AM
FL02SupaHawk996's Avatar
Fastest Color
amazing.
tim
The cost of rebuilding that shock is astronomical! $2.90 for a spring and $0.75 for o-rings...stock shocks are a lot cheaper...just stand up over the bumps
http://www.resuspension.com/8100-p-1-c-79.html
and just forget about the added
Old Jun 5, 2008 | 09:45 AM
lowell's Avatar
Simi Valley, CA
lowell is on a distinguished road
Fully adjustability Penske is worth the bling.
I am just saving for a new one.
It seems every bike I have owned I upgrade the forks and rear shock to make it "right".
THen I upgrade the brakes.
I never seem to upgrade the motor.
Old Jun 5, 2008 | 09:51 AM
Fastest Color
I agree that the SH motor is fine stock cuz it's got lots of torque, but it would be nice to stuff an RC51 motor in there
Old Jun 6, 2008 | 03:02 PM
Yeah, the oil alone is about 4 times that!
Old Jun 6, 2008 | 07:39 PM
Fastest Color
Dangit! Now you have to buy new oil too to rebuild that sucker
Guess you'd be better of running a 2x4 back there
RC
Old Jun 6, 2008 | 10:54 PM
filter69's Avatar
Thats Mr Dill hole to you
Well lets see new penske shock is 751.00 ge got used for 440 which is a differance of ....311 Dinars let find out how many rebuilds that is ....
Oil 16.32
Orings and misc 8.99
do it your self labor .Priceless
Shaft Wiper 8.00 (yea i know other shaftwipers too)
metering rod 7.00
and new pistons 1.50
for a total of ...Drum roll plz...35.81 total rebuilds 8 almost 9. im sold
Penske 2-Way Shock
$835.00 $751.50
Click to enlarge
Leveraging the 8300 adjustment, the Penske 2-Way series is engineered for motorcycle road racing applications. The Penske 2-Way features 25 click adjustable rebound damping, 40 click compression damping and remote reservoir. This model has low speed compression adjustment only.
Old Jun 7, 2008 | 03:42 AM
Fastest Color
Oil 16.32
metering rod 7.00
Penske 2-Way Shock
$835.00 $751.50
Click to enlarge
Filter, that red spring looks sweet! Nice rebuild pricing too
Old Jun 7, 2008 | 03:46 PM
Filter, do you work at a shop that does suspension? How are you recharging the nitrogen?
Old Jun 7, 2008 | 04:53 PM
http://www.motionpro.com/motorcycle/...ge_and_filler/
Old Jun 7, 2008 | 08:18 PM
filter69's Avatar
No I'm a HVAC tech nitrogen is an easy thing. I deal with high pressure
liquids and gases all the time. I have used my manifold guage set to recharge many reservoirs.
Hell for that matter you could prolly go to your local gas dealer and pick up a 40 cu. in nit tank and a regulator and be
filling in no time ...
Old Jun 8, 2008 | 03:10 PM
Regulator and tank are easy.. It's the set u0p to attach to and fill the shock.. Not as simple as a tire valve air chuck.
Being able to precharge the gauge, hose all the way to the needle valve is the key.. You get a perfect charge with zero pressure loss when you disconnect the set up.
Old Jun 12, 2008 | 07:35 AM
Fastest Color
Why not repressurize with air instead of nitrogen?
Old Jun 12, 2008 | 09:29 AM
FTMS's Avatar
Nitrogen is a lot more stable than air. It's pressure doesn't change do to temp.
Old Jun 12, 2008 | 10:04 AM
Fastest Color
Oh, that make sense, but does this? If you're not racing and just doing spirited commuting wouldn't you be okay with just air cuz it's 78% nitrogen?
found this surfing: Standard dry air is mainly composed of three gases: nitrogen (about 78%), oxygen (about 21%), and argon (about 1%). Together, these three gases make up 99.96% of dry air.
Old Jun 12, 2008 | 11:28 AM
filter69's Avatar
Well nitrogen is DRY and normal air is not so you would have to deal with possible corrosion. Also the normal air may react with the oil turning it acid
or what have you to many variable's just use nitrogen and all will be well
Old Jun 12, 2008 | 11:35 AM
Fastest Color
All good points Filter, but since I can't fart nitrogen and I don't want to pony up for the tank and filling regulator I'll just have to let you know if I get make any acid or get corrosion problems in my remote reservoir at my next rebuild interval...
Thanks bro!
RC
