WTB radiator fan
Old May 24, 2012 | 03:39 AM
niteridder64's Avatar
niteridder64 is on a distinguished road
WTB radiator fan
I would like to install a fan on my left rad. summer is coming.
Old May 24, 2012 | 08:16 PM
1971allchaos's Avatar
I have a couple of spare OEM fans... PM me with a e-mail - I will send you photos..
Old May 24, 2012 | 08:26 PM
saige's Avatar
the boss
there isnt much room to put a fan on the left side,and it will put a strain on the electrical.
if there is something you would like to do,put a switch,so you can put it on when ever you like.the one fan will do just as fine as 2.
flush system,put in recommended antifreeze.there is a certain type you have to put in,with some water wetter,and you should be good.distilled water only.
i ran this with never a issue.
Old May 25, 2012 | 11:02 AM
rocker4488's Avatar
rocker4488 is on a distinguished road
i have an extra oem fan as well. It could potentially strain your batt though if both fans kick in at a redlight (you are good if you are moving though). I actually like the idea of two fans (and run two fans on an undertail radiator), BUT i would recommend the second fan on a separate manual switch rather than on the same temp switch as your other fan. a good flush and proper antifreeze is also a good idea.
anyhow, PM me if you'd like to snag the fan.
Old May 29, 2012 | 05:42 PM
OK thanks for the reply, not sure if I will go thru with that project. I'll se how hot it gets this summer.
BIG DAVE 03
Jul 7, 2012 11:55 AM
nfbzike
Jul 30, 2008 06:41 AM
2sonrk
Aug 24, 2006 03:41 PM
cat0020
Jun 6, 2006 04:33 AM
inderocker
Jun 23, 2005 10:54 PM
