WTB motor / engine
Old Oct 9, 2009 | 10:41 AM
rhorsley's Avatar
rhorsley is on a distinguished road
WTB motor / engine
Due to prior owners bad shifting (it couldn't possibly be my fault!), my 2003 SuperHawk jumps out of 2nd gear back into neutral all the time. Since it's either shift forks, the drum or the gear dogs or all of the above, I'm looking for a low-mileage engine (under 15K) I can buy relatively cheap to swap into my bike while I tear down the current motor and do repairs. I'm in Sun City, Southern California (92585) and am willing to drive several hundred miles for the right price. I'm thinking $300-$500. I don't care if the side case covers are rashed or even cracked, since mine are fine and I can swap them out, but the motor needs to run strong and shift well. Anyone sitting on a spare engine out there?
OR
I would also consider a damaged engine (the price just dropped) that I can re-build / repair to replace my current engine. The key is that I don't want to give up my bike while I take my time to do the engine/trans work.
Old Oct 21, 2009 | 09:23 AM
Bridge_Boy's Avatar
Bridge_Boy is on a distinguished road
Hi, I'm looking for a front head (bent valves in mine) or a set of heads. If you come across some let me know.
Old Oct 22, 2009 | 03:11 PM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
got a complete motor w/ur same issue. jumps out of 2nd gear @ 5-6k rpm. good for rebuild. approx 20k on ticker, but reads high due to speedo error which we all suffer. Located in Galt, CA.
Old Oct 27, 2009 | 09:17 PM
rhorsley's Avatar
Hey loserbaby, thanks for the offer, but I really need one to swap in while I rebuild the current motor. The shift problem is getter worse all the time. I think swapping in a motor with the same problem would be a lot of work to have the same problem still.
Old Oct 28, 2009 | 07:55 PM
loserbaby's Avatar
jet wrench
huh??
QUOTE
"OR
I would also consider a damaged engine (the price just dropped) that I can re-build / repair to replace my current engine. The key is that I don't want to give up my bike while I take my time to do the engine/trans work."
I replied to YOUR ad!
LB
Old Oct 29, 2009 | 08:35 AM
rhorsley's Avatar
Hey loserbaby, sorry if I offended your sensitivities, but maybe you should read the original post a little better! I said I was looking for something under 15K miles and I am willing to drive several hundred miles. You're offering a damaged engine/trans with about 20K miles and a THOUSAND MILE round trip to get it. Like I said in my reply to your offer, with the shift problem getting worse, I'd prefer to have a solid engine/trans to swap in so I don't lose my transportation while I re-build.
sgv_vtr
Aug 15, 2011 06:22 PM
smokinjoe73
Jul 18, 2011 07:52 AM
Iggyflywheel
Jul 1, 2011 05:18 AM
Byrdman
Sep 7, 2009 02:02 PM
gssbmm
Sep 7, 2006 09:43 AM
