Parting out custom build hawk
Entire 2007 cbr 1000rr front end everything the top triple has been drilled for bars so you may want a new one. (forks both triples straight wheel axle rotors calipers) its all there. $500
2007 cbr1000rr tail end complete and modified to bolt onto the super hawk (subframe undertray and race cowl) Sits a little high which I liked but you may or may not easy to change/adjust if your handy with a welder. $175
2001 VFR Swingarm complete (shock dog bones '98 wheel caliper NO ROTOR) $500
Belly pan needs paint not cracked anywhere $50
Front fender needs paint not cracked anywhere $50
Hand controls ECU wiring harness motor (2005 9k miles) carbs clean title frame ect ect all must go Ill work anyone on here a decent deal Ebay is next but Id rather disperse here. I have a complete bike so more than likely I have what you need rear sets airbox all kinds of stuff. All from a 05 No front end parts no rear end parts and no subframe tail parts.
All prices plus shippping OBO wanna move this stuff ASAP
Cush drive
Cush drive
Was the VFR swingarm bolted up and working on a Superhawk? In other words, this is a complete swingarm, bolt it up and go? Any pictures?
Is this a stock chin fairing? If not, do you have any pictures?
Yes and yes, you have to drill the frame up by where the fuel tank mounts for the shock its still on the bike heres a pic. The chin was painted blue wont match anything.
Forgot to add one of the forks is seeping oil and comes with a set of OEM seals.
5. eBay links may be posted, however the seller must post a price here and be willing to end the eBay auction early for Superhawkforum.com members.
6. Failure to follow the above rules may result in the post being removed and/or loss of privileges to use the Classified forum.
captainchaos
Apr 16, 2015 06:12 AM
BiggDaddyKool
May 31, 2007 01:36 AM
