Oxford Heaterz - heated grips
This is a complete and functional set of Oxford's original-style heated grips. The grips in this kit have never been installed or used. The control module was installed briefly and its power and ground leads were modified to fit blade-type accessory plugs - the original ring terminals were replaced with blade plugs. The switch was used briefly as well, and it has a factory defect that does not affect its functioning: the 75% LED does not come on, but that power setting works properly. (None of the LED's can be seen in sunlight, anyway.) Also, the switch does not allow for going back down through the sequence of settings; you can only go up and then turn it off and back on to start over at the lowest setting. None of this affects the actual heating of the grips, which is quite strong. I would have returned the defective unit, but I waited too long to install it after purchasing, and couldn't send it back, especially after modifying the control module's connectors. All mounting hardware is included and there are no other problems.
It's a long story how I ended up with this collection of parts, but basically I've put together one whole kit from remnants of a couple others. I installed this control module and switch on my bike for a brief period (one week) with other grips (identical to the ones in this kit), and it worked fine. But I ended up piecing together a different setup for permanent use, mainly because I have small hands and the somewhat thicker Heaterz grips never felt right to me.
This kit can be purchased for $65-80 at online retailers (without shipping). I'll take $30 for this set, shipping included to continental US. I'm set up to take PayPal. PM me if interested. I can take and send other photos of individual parts, if you like. Thanks!
