lightened flywheel
Old Aug 28, 2011 | 03:59 PM
lightened flywheel
Had my spare flywheel turned down the std. .5" off the OD
$75 plus shipping (usps $15 in the US)
or if you're in the bay area, you can come by and pick it up and I'll even install it for you if you need.
Old Aug 28, 2011 | 04:05 PM
Oooo... pm'ing now...
Old Aug 28, 2011 | 04:19 PM
PM replied.....
Old Aug 28, 2011 | 04:32 PM
Sold...... in 6 mins flat.....lol
Old Aug 28, 2011 | 04:57 PM
saige's Avatar
the boss
holy jesus,that might be the fastest on here,was there ever any faster lol
Old Aug 28, 2011 | 05:01 PM
Well, at least the lightened flywheels works!
When it's 112 degrees in Phoenix, afternoons are for laundry and forum sniping
Old Aug 28, 2011 | 05:55 PM
So whats the deal on the flywheel? Quicker reving? Does it enhance performance or percieved performance?
Old Aug 28, 2011 | 05:56 PM
autoteach's Avatar
It lengthens your...you know...it's awesome
Old Aug 28, 2011 | 06:18 PM
The engine will accelerate & decelerate quicker and while there is no gain in HP the energy that was used to accelerate the mass of the heavier flywheel is now used to accelerate the rear tire.
So yes it does enhance performance.
Old Aug 29, 2011 | 05:27 AM
Revelation's Avatar
Revelation is on a distinguished road
Best "value-for-money" modification I ever did!!
Feels sooooo much faster. Aspecially in combination with 15-41 sprockets.
On my black one I am running -10%
On the one I am building, I am going for -15%
Old Aug 29, 2011 | 12:15 PM
jeephawk's Avatar
jeephawk is on a distinguished road
You had a half inch machined off the o.d.!
Sounds like alot. Wouldnt that throw the balance off?
Gotta be a typo.
Old Aug 29, 2011 | 12:23 PM
Gotta be a typo.
Yes.....
No.....
No.....
Old Aug 29, 2011 | 12:30 PM
Big Shepp's Avatar
Big Shepp is on a distinguished road
Essentially RWH figures are somewhere around 15% lower than the crank horsepower. This is because the engine has to centrifugally accelerate all the moving parts in the drivetrain. By lowering the mass of these parts, you decrease the amount of power the drivetrain pulls from your engine and thus increase your RWH without increasing your crank horsepower.
Old Aug 29, 2011 | 01:43 PM
jeephawk's Avatar
crazy.
so whats the trade off? less torque.
Old Aug 29, 2011 | 02:00 PM
crazy.
How could removing mass from the flywheel cause the engine to produce lees torque?
IMHO the VTR as way too much mass in the flywheel as a safety feature to keep hamfisted riders from flipping it over backwards in 1st. Yes mine will flip over on its back with no problem.....
What you end up with is a engine that produces the same HP & torque but rev's like an RC51.
Old Aug 29, 2011 | 02:05 PM
crazy.
If you really need to find a downside to the mod, there is a small one... Like hawk said, the VTR's large flywheel is a "safety feature", and if you ligthen it, the bike becomes a bit unruly if your not careful with the throttle...
Old Aug 29, 2011 | 02:58 PM
From what I've read, aside from the twitchy throttle, and depending on how you ride, you may lose some mpg, especially at cruising (as there is less inertia keeping the components moving).
Old Aug 29, 2011 | 03:23 PM
mboe794's Avatar
Gotta be a typo.
I took half an inch off the radius of mine. Or, in other words, a full INCH off the diameter. The shop said they ckecked it afterward, and it needed no adustment for balance.
Removing material from the outer edge should actually make balance less of an issue.
Old Aug 30, 2011 | 02:26 AM
It CAN affect balance, but the more you remove, the lower the resulting imbalance will be...
It's simple really, X% of the total weight is the imbalance, and when the total goes down, so does the weight of the imbalance, even if the % stays the same... Plus, the resulting radius that acts like a fulcrum for the weigth becomes less, so all in all, even with an inherent imbalance, the % will drop as well... It's physics...
Old Aug 30, 2011 | 02:29 AM
Well, yes and no... It's not going to affect the mileage either way really based on the flywheel... But since it's not smoothing out what you do, if you are inefficient with the throttle, it becomes much more apparent...
Ie if you are ultra smooth and efficient, the lower flywheel weight can actually help you conserve fuel... Unlikely, but it's a possibility...
Old Aug 30, 2011 | 05:15 AM
nothing's Avatar
ride it out
is it hard to remove the flywheel I've never done it.
Old Aug 30, 2011 | 05:45 AM
RWhisen's Avatar
Former Superchicken Owner
I would think that it would have a less consistent idle as well.
Old Aug 30, 2011 | 07:20 AM
As far as I can tell, the idle remains the same, equally consistent as before...
But then, my bike is dead on in terms of carb syncronization and other factors, so I can easily drop my idle below spec and it will remain stable... If the bike is setup a bit less precise, and prone to stalling or other misbehaviour at idle, then yeah, a lighter flywheel will make that worse...
So my interpretation would be the same as with fuel consumption... It doesn't change the characteristics, it just shows the flaws based on other things more clearly...
That's the basic flaw of modifying your engine... To get more performance out of it, you tighten the specs... And that more or less forces you to do that across the board, tweaking just about every detail a small amount...
darylward
Oct 12, 2011 01:18 PM
dbog44
Oct 21, 2010 07:08 PM
nfbzike
May 17, 2009 03:19 PM
autoteach
Jun 23, 2008 02:02 PM
mikstr
Feb 6, 2006 04:14 PM
