gas tank bolt
Old Aug 20, 2011 | 10:25 AM
saige's Avatar
the boss
gas tank bolt
would anybody have the gas tank bolt that holds the back of the tank on the bracket.mine snapped and need one.
part number 90135-MS2-000
thanks
Old Aug 20, 2011 | 10:39 AM
killer5280's Avatar
I replaced mine with one from the hardware store. The bolt and nut have 11mm heads instead of 10mm like the original, but it works fine.
Old Aug 20, 2011 | 10:55 AM
saige's Avatar
the boss
is it close to oem thickness and such,so there is no wobble.
Old Aug 20, 2011 | 03:52 PM
zmaniv's Avatar
Redhawk98 has one
Old Aug 20, 2011 | 08:51 PM
Thumper's Avatar
In a Pinch i have found that Ace Hardware has a superior Metric bolt and nut selection compared to lowes or home depot.
Old Aug 21, 2011 | 12:06 AM
killer5280's Avatar
Yep, and I got it at Ace Hardware like Thumper recommends.
Old Aug 21, 2011 | 04:56 AM
90135-MS2-000 - BOLT, TANK HINGE - Honda OEM Parts - Cheap Cycle Parts
BOLT, TANK HINGE - Search : 90135-MS2-000
Ronayers is a little cheaper...
Old Aug 21, 2011 | 04:57 AM
+1 I've often found Ace to somehow pack a better selection of things I need into a space a tenth of the size of home depot or lowes.
Old Aug 21, 2011 | 06:33 PM
saige's Avatar
the boss
thanks guys,i will check these out and see if i cant find what i need.
Old Aug 21, 2011 | 07:18 PM
I was wondering if I was the only one who noticed this.
Old Aug 21, 2011 | 08:51 PM
killer5280's Avatar
You're not alone.
Old Aug 22, 2011 | 09:22 AM
PUSHrod's Avatar
We are not alone.
ckoscin
Jul 29, 2011 03:54 AM
chadnol10
Jun 19, 2011 08:08 PM
salmanilla2000
May 9, 2011 12:05 PM
salmanilla2000
Apr 27, 2011 10:41 AM
Jaymidd
Mar 11, 2010 02:13 PM
