Garage Clean out
Garage Clean out
I am cleaning out the garage of some misc parts.
All prices include tracked shipping, larger items will not be tracked and will ship the cheapest way unless otherwise arranged.
All taken from my 2004 model.
Front Fender $50 Some small minor scratches, must be really close to see.
Steering stem top and bottom $40 - Quite a few scratches on the top stem all bolts included
Right Muffler $80 - No dents, minor wear. Probably want a new clamp as it too is rusted solid
Turn signals $ 30 - All four working with bulbs
Front Brakes $60 - Full front brakes lines, master, callipers, and some misc mounting bolts
Left switch $20 - might have one wrong plug as two wires are free, I did switch to the European switch and might have switched a plug
Wheel bearings $10 - Front and all three rear, only taken out to put in hybrid ceramic ones
Clutch line $20 - with master NO lever or mounting clamp
Coerce Stabilizer $140 - some wear, bolt on and go
12V outlet $10 - 12 volt outlet for what have you
Rear Brake disc $10 - normal wear, some heat marks in center as seen
Seat $100 - Stock seat, extremely uncomfortable as normal
Galfer pads $40 - Brand new Galfer pads semi metallic only one set
License plate holder/light $10 - normal wear, lights up your plate at night
Bonus:
Aluminum Velocity Stacks $150 - Only a few sets left from the run I made last year, will not be getting anymore made.
SOLD Exhaust $80 - No dings or dents, will need a new clamp as it is rusted solid
[img=http://s14.postimg.org/lou53pmf1/IMG_0345.jpg]
[img=http://s14.postimg.org/6dfqpczp9/IMG_0346.jpg]
[img=http://s14.postimg.org/53hxab5x9/IMG_0454.jpg]
[img=http://s14.postimg.org/g6wy261tp/IMG_0455.jpg]
[img=http://s14.postimg.org/6nn98pebh/IMG_0456.jpg]
[img=http://s14.postimg.org/rhzlqj8ot/IMG_0457.jpg]
[img=http://s14.postimg.org/t63cixby5/IMG_0458.jpg]
[img=http://s14.postimg.org/9cr8q7ykd/IMG_0459.jpg]
[img=http://s14.postimg.org/xvta7j2yl/IMG_0461.jpg]
[img=http://s14.postimg.org/avmmv754t/IMG_0462.jpg]
[img=http://s14.postimg.org/8alnlf54t/IMG_0463.jpg]
[img=http://s14.postimg.org/es4k4xfi5/IMG_0464.jpg]
[img=http://s14.postimg.org/qrg2c8l31/IMG_0465.jpg]
[img=http://s14.postimg.org/jpi4q1hh9/IMG_0466.jpg]
[img=http://s14.postimg.org/vh600uc3h/IMG_0468.jpg]
[img=http://s14.postimg.org/xbiuikz3x/IMG_0469.jpg]
[img=http://s14.postimg.org/o2go8gq7x/IMG_0470.jpg]
Bonus:
UFC Eric: It is just the clamp that holds the main exhaust to the short small one, the bolt rusted and snapped off. The rest of the exhaust is fine no dings I could see. It is the stock exhaust.
Scottiemann: The PDF file is available only as the shop keeps the machine files. I had a few extra I had made, if you have access to a machine shop you can do it for cheap but otherwise you basically have to get 10 or more sets made at a time to make it worth doing.
calitoz
Aug 20, 2009 07:25 PM
