CDI circuit board question
Old Feb 12, 2017 | 01:46 PM
Jcj's Avatar
Jcj
Jcj is on a distinguished road
Hi I am new to the superhawk forum I have a issue with one of my ignition coils not firing does the CDI have a separate circuit for each ignition coil any and all info will be greatly appreciated.
Old Feb 12, 2017 | 04:17 PM
Cadbury64's Avatar
VTR virgin
Certainly looks like two signal wires going from the ECM to the converter unit.
Step one is normally to swap the coils over and see if the fault follows the change, or stays the same. It is not unknown to have a break in one of the low tension cables leading to a coil, and an end-to-end resistance check from the converter plug to the coil terminal would assist in diagnosing that.
Old Feb 12, 2017 | 04:23 PM
Jcj's Avatar
Jcj
I tested the ignition coil and it is working fine
Old Feb 12, 2017 | 05:30 PM
basford's Avatar
basford is on a distinguished road
I had a problem with the coil firing . Wound up being a bad ground from the rectifier. If you find grounds are good I have both CDI boxes, rectifier, and coils up for sale.
hopefully you can track it to a ground problem before you spend a bunch replacing parts. If you resort to replacing see my thread with those parts forsale
Old Feb 12, 2017 | 05:38 PM
Jcj's Avatar
Jcj
I tested the ground wire with a test light and it turned green I also tested the power wire with the same test light and it didn't turn green.
Old Jun 15, 2025 | 12:25 PM
Westuck's Avatar
Westuck is on a distinguished road
Also I don't know the specs on the coils and do these bikes have a immobilizer or a resistor in the switch for security? Do these bikes have one or two pulse generators I only saw two wires coming out of the clutch case that may be them I'm not sure but the run to the front of the bike which idk what there connected to in the front
Old Jun 18, 2025 | 08:27 PM
Howdy,
The factory service manual is a free download, have you found that yet?
peterdamian2000
Buyer/Seller Feedback
Dec 6, 2009 11:41 AM
Erik S.
Aug 18, 2009 06:16 PM
Flying Dutchman
Apr 1, 2008 05:26 PM
ClevelandSuperhawkRumble
Oct 21, 2005 03:02 PM
Rollingalong
Feb 11, 2005 04:49 AM
