Carb Parts
Old Oct 31, 2019 | 04:59 PM
ACE VenTRa's Avatar
Carb Parts
Just gauging for interest...
I have 2 carb bodies, diaphragms and random parts for sale if needed.
Let me know and I'll post pics
AV
Old Mar 31, 2020 | 09:02 PM
Cshelton03's Avatar
Cshelton03 is on a distinguished road
Needs!
I need a choke cable with the plunger attachments to the carb. My intake boots were hard as a rock as well. Do you have a price on either of those?
Old Apr 1, 2020 | 04:04 PM
ACE VenTRa's Avatar
I think I have a choke cable set, let me check and if they look reasonable to you, please pm me an address so I can quote shipping.
AV
Old Jun 8, 2020 | 01:28 PM
I could use one slide and the front and rear jet needles, can you help me?
Thx
Old Jun 8, 2020 | 03:05 PM
ACE VenTRa's Avatar
Absolutely. The needles are from DJ. The slide was at one point drilled with an extra hole has been filled but the diaphragm is good. I can send you pics later. Standard flat rate shipping is about 13.00. Send me a PM with mailing address and I'll send a total cost.
Thx
AV
Old Jun 8, 2020 | 06:33 PM
Thx
AV
Thanks but I already have DJ and FP needles. I was looking for OEM needles as they seem to be easier to tune unless you've got some suggestions for the DJ needles. I compared them to the dimensions of the stock needles and was going to put them on the second clip from the top and shim them 40 thousand for the rear and about twenty thousands for the front. I wasn't sure if the DJ needles are the same between the two carbs or if FP needles are identical front and rear
I also want a stock slide with the lift holes unmolested Can you help me? Thanks again
Old Jun 9, 2020 | 03:30 AM
ACE VenTRa's Avatar
I think that if you are having issues with 2 different types of needles then the issue is not the needle. The DJ and the OEM needle are almost identical but I suspect that you have them too low. Also, I do not run them on different heights, I make the needles, pilots, and AF screw the same and only change the main. When mine was relatively stock it liked 180/185 mains 4th clip and 2 ~2.5 turns out. For reference, each clip height on the DJ is about .020 so if you change the stock needle .020 with a shim, it is the equivalent of running a full clip height different and that is substantial.
If I knew more about your setup, altitude and climate I could tell you more. Symptoms too.
What about the TPS, Cam Sync, Valve Adjust, slide springs, lift holes?
AV
Old Jun 9, 2020 | 07:07 AM
I'm not having problems, I'm cleaning and rebuilding a set of carbs for a spare set for a friend from two other sets that were all fouled up with a mish mash of parts. I've been tuning VTRs for literally decades for our locale in northern IL and southern WI. For a stock engine and air filter with properly adjusted valves, I've found 48 pilot jets and either Keihn 175/178 or at most 178/180 main jets, the fuel screws 2.25~ 2.5 out, with the OEM needles shimmed .020 ~ .040 in untouched slides and springs usually gets it pretty darn close after proper syncing and setting the TPS at around 500 ohms. I'm just not sure which sets of after market needles are which. One pair are longer than stock with a longer tip below the taper. The other set are closer to stock. Maybe the longer set are Factory Pro and shorter are Dynojet. I know each clip is .020" .
Thanks for the input though.
Old Jun 9, 2020 | 07:13 AM
ACE VenTRa's Avatar
Carbs
I can measure my dj needles later if that helps.
Old Jun 9, 2020 | 05:06 PM
Thanks, when you have time. For now I installed my only spare set of OEM needles shimmed .040", stock slides and springs with the 48 pilots, which has been a proven setting in the past. I also run a long velocity stack on the front carb which is supposed to improve the bottom end; it's hard to tell though.
Old Jun 10, 2020 | 03:16 AM
ACE VenTRa's Avatar
Np
Ok, good luck. What the shop you work out of? I'd like to know more about your history with the v and what you might have learned over the years.
Av
SaucyDinosaur
Apr 25, 2018 07:21 PM
Babelfish
Apr 11, 2015 12:52 AM
afm528
Aug 27, 2013 03:55 AM
Shawn Torpey
Feb 12, 2007 04:31 PM
