Alright gents,
here is what's up for the VTR this Spring: 1) RC-51 front calipers with EBC HH pads 2) re-packing the Microns 3) Hyperpro progessive shock spring 4) shifter linkage mods (will re-set on splines, likely do heim joints too... love this forum!) 5) replace headlight bulb with GE Nighthawk (same wattage) 6) flush-mount turn signals 7) bar-end mirrors 8) Vista Cruise 9) Speedohealer I picked up some exhaust paint (flat black, and red) and so will be painting the cans flat black, along with the brake calipers (but will highlight the Nissin in red)...poor man's "bling", lol Also, I was given some TufOil samples through work so I may try adding a bit to the engine oil. I did some Google research and found no bad resports (ie. clutch slippage) but did find some positive stuff (improved shifting,...) so I may take the plunge (would do so very slowly though just in case). Any of you folks have experience with this stuff in bikes? cheers |
Scottiemann,
I have a similar setup (or had anyway before I went single sided) with Hindle cans. I have settings on my website. Go 1 or 2 sizes down on the mains. Everything else should be good. |
Pics of Napoleon mirrors
Hi All
Cant figure out how to post pics to the forum. I have 3...all jpegs, all 1200 X 1600. All blow the size limit on the forum. We have Adobe Photoshop 7.0 and it wont let me change the size. Or I cant finger my way thru to the solution. sigh. Can somebody walk me thru this? Cheers! Geoff in Almonte (aka vtrgeoff) Ontario |
Geoff,
Are you trying to attach to a post or put them in the photo album? To change the size in Photoshop, select Image>Image Size. Also to save for the web select File>Save for Web. |
Napoleon pix
3 Attachment(s)
lets try this.....
What bar risers are those?
What is the grab Bar?
Bar risers are Helibars.
Grabrail is Ventura. Geoff in Almonte |
