Weird front end feeling while leaned over
Old Apr 21, 2009 | 06:09 AM
willz's Avatar
willz is on a distinguished road
Hello all,
So its finally started to get a little warmer around my area and I've started hitting the twisties a little but I've gotten a really weird feeling from my front end. I'm not a suspension guru so maybe I just need some sort of adjustment that I can't figure out. This has happened the last two times i've hit the twisties.
While leaned over on the left side (same corner both times), mid corner, off the brakes and just holding steady throttle (just before rolling it on) I get a feeling like the forks are sort of going up and down. Not too fast, but maybe completing the up-down cycle 1-2 times a second. Its pretty weird and not something I've felt before on my old bike (CBR600). On that bike I had a friend help me out with the suspension but I can't remember any of the order to do it in. I know there's a Sport Rider article I can look up for help with that if thats what it is.
Is this just a matter of stiffening up the suspension? I got the bike last year with about 1k miles and haven't done anything with the suspension yet so I'm guessing its still set to factory specs (I'm guessing too soft). If it is the suspension what specifically causes this? Rebound damping? Thanks for any insight...
Will
Old Apr 21, 2009 | 08:27 AM
RCVTR's Avatar
It sounds like you need a couple clicks of rebound damping (clockwise on the adjuster on top).
That should help a lot. But to really make the fork work requires some internal work.
Old Apr 21, 2009 | 08:39 AM
chickenstrip's Avatar
chickenstrip
Did you check tire pressure?
Old Apr 21, 2009 | 09:45 AM
Circuit_Burner's Avatar
guru of things sparky
Nevermind the bent wheel, or the steadily growing tire bubble on the sidewall.
Old Apr 22, 2009 | 02:38 AM
shayne's Avatar
Do a search on suspension on here, and you will find lots of info.
Unless you are really light guy then the springs will be too soft. The valving is also to restrictive, that is why people instal Race Tech Gold Valves. These will fix your suspenion up nicely.
Hawkrider can do suspension work for you. Other members have been happy with his work so you could send him a PM.
Old Apr 22, 2009 | 03:57 AM
gboezio's Avatar
Is the steering moving a little, like a slow wobble ??
Old Apr 22, 2009 | 04:28 AM
justscoutin's Avatar
justscoutin is on a distinguished road
I got a slow wobble in a right hand turn the other day. wierded me out. setup the suspension properly for my weight and haven't felt it since. gotta try out that corner again though.
Old Apr 22, 2009 | 05:38 AM
willz's Avatar
Tire pressure is good.
No wobble in the steering. It almost felt like weaving a little too.
I'll try and set up my suspension with a buddy this weekend and then maybe look into the Racetech Gold Valves.
Which Gold Valves are people using? There seems to be 4 options on their website.
http://old.racetech.com/evalving/eng...ngname=english
I'll contact them and see what they recommend for me...
Thanks for the help all.
Old Apr 23, 2009 | 08:24 PM
nath981's Avatar
there's a couple guys on this forum that do forks/shocks at a much lower price than race tech and most likely with more attention to detail/tlc and quicker>get er done!!
scpt kirk
Aug 4, 2012 01:53 PM
bluesman
Aug 30, 2007 03:32 AM
TheDarkKnight
Aug 1, 2007 09:00 AM
Dave Wicks
Jun 11, 2007 08:33 PM
EngineNoO9
Sep 2, 2006 09:15 PM
