SuperHawk Forum
-   -   Upper Fairing mounts - which one goes where? (https://www.superhawkforum.com/forums/technical-discussion-28/upper-fairing-mounts-one-goes-where-27865/)
Spoot Mar 24, 2012 08:02 PM
1 Attachment(s)
I've been looking around....can't seem to find good info.
Also looking through a bunch of pics, it's hard to tell.
The SH has 4 aluminum fairing mount things. Each in a "Z" shape. 2 small, 2 large.
The 2 small have a slight angle to them. The big ones look close, but one has a little groove built in.
I bought my SH naked and I am now trying to mount the upper, but I've never seen a hawk with it's clothes off to see which one of these goes where?
So far, I have deducted that the small ones go lower/center of the bike ( i found where they mount) and large ones go up by the tank. But still...which one where? Should they point forward/down/back/up?
Plz help.
Thanks.
1971allchaos Mar 24, 2012 08:31 PM
WELLL, Spoot (?) the two brackets in the center of you photo - This is a Trial and Error procedure.. because -you can mount the brackets on either side... No way to confirm to you bracket goes where...
Your correct on the lower/back/smaller bracket...
PATIENCE.. is the key/ good luck..
Spoot Mar 24, 2012 09:28 PM
should they point up/down/back/forward?
I guess there is only 4...I could just start mix-n-match then test fit...rinse/repeat.
Spoot Mar 24, 2012 10:10 PM
2 Attachment(s)
ok. got it figured out....I think. I only have an aftermarket race upper, but I think it should be the same for OEM mounts.
First up, the little ones.
They each have a little offset to them.
They mount with the threaded hole out/away from the bike.
They mount with the outside tab pointed toward the front of the bike.
The rightisde mount will slope toward the ground.
Spoot Mar 24, 2012 10:11 PM
The other little one mounts the same way, just on the left side of bike.
Spoot Mar 24, 2012 10:14 PM
2 Attachment(s)
Now, the longer ones.
Threaded part out/away.
It mounts along the slight angle-cut and will basically point to the "N" in Honda - on the tank.
Spoot Mar 24, 2012 10:18 PM
1 Attachment(s)
The last one has a guide/groove on the base.
Again, align with the slight angle-cut and point toward "Honda"
